Trans Go Install Questions.... Need Help!!
Old Apr 15, 2001 | 05:34 PM
fast89's Avatar
I am installing the Red, Blue and White box version of the Shift Kit and it wants me to open a few holes a little larger. I do not have the equipment necessary to open these holes just a little bit like they are requesting. Is this necessayr or can I forget about this step???
Secondly, what has been the best washer combo used by the 700r4 trans for shifting??? I am at this step and I am wondering how many to put in. I know every car is different, but I need a good base to start at.. I am a novice at trans work and this kit is EXTREMELY intense!!!
Thanks for the help in advance. I will be on-line most of the evening, so any help would be appreciated.
1989 Pontiac Formula L98 Ported Plenum, Edelbrock 6085 Heads, Edelbrock HI-FLO Intake, BBK 52MM TB, Edelbrock TES, FlowMaster 3" Exhaust, Dual Cats, 3.27 Gear, CompuCam 2032 Cam, 1.5 Rollers, Ed Wright FastChip, Accel Super Coil, MSD 8mm Wires
Old Apr 15, 2001 | 06:37 PM
Pro Built Automatics's Avatar
Yes, it is a very necessary step, go out & buy the bits recommended. You can start out with 2 since you have 3.27's. If you want call me at 800 7763288 it is 4:32 PST right now and I will be building the rest of the evening (next 6 hours or so).
Hope This Helps!!!
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
The_Phoenix
Feb 4, 2016 07:10 AM
TheJoeY88
Aug 13, 2015 06:51 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
