speed O calibration
Old Jan 8, 2009 | 04:41 PM
lnsper's Avatar
Car: 92 RS
Axle/Gears: 3.27 4 wheel disc
speed O calibration
I have a 92 RS that I replaced the rear end I installed a BW 9 bolt with 3.27
gears I think the stock rear end had 2.73 do I need to change any thing in the trans to correct the speed O
Old Jan 11, 2009 | 09:49 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: speed O calibration
Yes, you need to change the drive gear and driven gear in the tailshaft of the transmission.
You can this forum for "3.23 speedo" or "3.27 speedo" and find the correct gear sizes and probably the part numbers too.
Old Jan 11, 2009 | 10:36 PM
lnsper's Avatar
Car: 92 RS
Thanks Kevin91Z
I got a chart from my local cheye dealer and all I need to change is the driven to a 45 my drive will stay the same its a 17
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
RedLeader289
Sep 23, 2015 06:50 AM
adelane
Sep 9, 2015 08:51 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
