I'm confused and need some help
Old Apr 15, 2001 | 10:33 PM
JPrevost's Avatar
Car: 91 Red Sled
When I had my old 305 TBI w/ headers and SLP shift kit my 3.08 pegleg would feel like the rear of the car was kicking out in one direction between the 1-2 shift. In the rain the car would loose traction real bad from the hard shift. I'm afraid that when I take it down the track now (with the 350) that the rear end is going to snap and kick like that and I'll get a little crazy. Is a pegleg dangerous when going down the 1/4 when you have 90% more power than stock and hard shifts?
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 16, 2001 | 11:53 AM
raging86's Avatar
i wouldn't think so. in a front wheel drive car that has some nuts you can feel the power "hunt" from wheel to wheel, but it doesn't really make the front of the car go all over. like wise with a one legger rear end, the power will spin the one with the least traction, and unless you completely loose traction with both wheels you aren't going to loose control. i know what you are talking about though, my 86 iroc runs pretty strong, and it has a 3.23 one legger with a shift kit. on a good wide open upshift, the tires will chirp and the rear of the car will slide to the right about 3 inches, my dad's monte SS did the same thing with it's 3.42 open rear. i'm not sure why they do it, but i have never felt as if i was about to loose the car.
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
shift kit, manual TC switch, manual fan switch, flowmaster exhaust with edelbrock TES headers& hollow cat, gutted MAF.
Old Apr 17, 2001 | 04:52 AM
JPrevost's Avatar
Car: 91 Red Sled
Okay, I think I'll be okay. I'm just really careful since I just got the car restored from the total and now the new engine. The posi cars I've been in haven't had that rear end kick as bad as mine, not sure if my shift kit is harder or what but it's scared a few of my friends.
  • 8" harm. balancer
  • Alston SFCs
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
