transmission problem? 700R4
Old Jan 9, 2009 | 04:27 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
I finally got my camaro looking good and running great. So my girl wanted to go for a ride. Of coarse I had to end the ride with a few donuts. Well when I drove off it never hit third gear. After 2nd gear it seems like it goes to neutral. It just revs up when I give it gas.
Old Jan 9, 2009 | 05:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: transmission problem? 700R4
Time for a rebuild
Old Jan 10, 2009 | 03:48 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Originally Posted by Apeiron
Time for a rebuild
X2
but it's probably cheaper to replace.
Old Jan 11, 2009 | 02:59 PM
Car: 91 RS T-top
Time for a rebuild
I can buy a new better one for less than a rebuilt one. ha. But I guess thats what it will have to be
Old Jan 11, 2009 | 03:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Your "new" one is probably remanned as well, and wouldn't be as good as a good rebuild.
Old Jan 11, 2009 | 05:15 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
When i swapped my super t-10 4spd for a 700r4 i just went to my favorite junkyard and grabbed a 700r4 out of
an '85 caprice(110,000 mi on it),put in a shift kit,used a
tci converter and installed it-130,000 mi later(did this in
'95)still going strong.
700r4 was upgraded ist in 1984 and again in 1987 when
a stronger sprag was installed
probably could just repair the problem with the tranny
instead of a full(expensive)rebuild.
BTW did you check the fluid-might have only sucked some
air when you did the donuts. I got my tranny for $100-
took it out myself.
Old Jan 12, 2009 | 09:57 PM
Car: 91 RS T-top
yeah i just added half a quart a week before this happened and I just put it in a few months ago from my other camaro that had half the miles on it. Ill crawl under the car tomorrow when I get back home in Texas . Thanks for the Ideas
Old Jan 13, 2009 | 12:45 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
you could probably just do a 3-4 clutch repair.
pull the trans., stand it up on a bucket, pull the pan-filter-aux tube if it has it from the pump(it should have it it's a 1991)-and t.c.c solenoid. Pull the pump bolts and pump(you can pry the pump out gently between the reverse input drum and the pump body), release the band anchor with a screwdriver or small pry bar. then grab the input shaft and pull out the band drum with input drum. the input drum houses the 3-4 clutches and they will probably be burnt. replace the clutches and steels-throw away the return springs(5 of them). NOTE:you should break down the input drum and replace the inner rubber-i'd have a shop do that for you because you need special tools to get the pistons back in without ripping the seals. when you get the drum back install all in reverse order with a new filter, pump gasket, pump o ring, and new torque converter seal, pan gasket-oil. you can do it danielson-wax on wax off..
Old Jan 14, 2009 | 08:45 AM
Car: 91 RS T-top
sweet thanks. Ill have to give that a shot. Of coarse ill have to wait until I get a day off but I will try that. Thanks again
jhawkeye
May 25, 2022 06:33 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
stalkier
Dec 6, 2015 11:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
formula_novice
Aug 18, 2015 08:48 PM
