tranny swap
Old Apr 12, 2001 | 10:09 AM
raging86's Avatar
tranny swap
hey guys i have an 86 tpi IROC. i want to swap in a 6-speed and i was told that the crankshaft in my 305 may not be drilled to accept a flywheel? is this a possibility? some moron mechanic told my dad this and i don't think it is true, does anyone else know about this?
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
shift kit, manual TC switch, manual fan switch, flowmaster exhaust with edelbrock TES headers& hollow cat, gutted MAF.
Old Apr 12, 2001 | 07:26 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
<font face="Verdana, Arial" size="2">Originally posted by raging86:
</font>
Must be talking about the bolt pattern for the flywheel to crank. No it will not work, but you can order a flywheel (centerforce) that works with the T-56 and bolts to a two piece seal crank.
Try this link:
http://www.sethirdgen.org/t56.htm
it should answer a lot of questions about the swap.
HTH
Old Apr 16, 2001 | 11:43 AM
raging86's Avatar
ok then how come i haven't heard anyone else say anything about this?
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
[This message has been edited by raging86 (edited April 16, 2001).]
Old Apr 17, 2001 | 10:31 PM
raging86's Avatar
can anybody confirm this? moderators?
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
Old Apr 17, 2001 | 10:56 PM
ScreaminDeamin85Z's Avatar
i can confirm that your crank will not work because i am in the process of doing this right now and you HAVE to order a lt1 specific flywheel that will fit the larger journal 2 piece rear main crank. centerforce makes it and the part number is; 700107 (about $250-300)
phone #; 1-800-932-5882
or you can click on this link and it will take you to the page.
http://cyber.virtualrep.com/centerfo...eelresults.tpl
any more ?'s
to save your time you could do a search
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old Apr 18, 2001 | 01:13 PM
raging86's Avatar
thanks a bunch for the info screamin.
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
Old Apr 18, 2001 | 10:45 PM
no problem man i just thought i would save you the time, instead of you having to call the main companys the manufacture clutches and flywheels, and sit on hold for 20 min like me.
Brandon
New project-89 IROC
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
