Automatic Transmission in lock mode
Old Jan 11, 2009 | 03:13 PM
hs1322's Avatar
Car: 82 Camaro Z28 T-Tops
Engine: 350 Carb
Transmission: auto
Axle/Gears: Don't know looking to replace,
I have an 1982 Carmaro and just put in a 350 chevy engine in it. I drove it yesturday for about 6 miles and went to take it out this morning and found that it wont drive forward or in reverse....It sesms to be locked into a neutral position. When I move the stick into Park I get a loud grinding sound. Can you give me any suggestions on what may be going on. Just need to trouble shot and get resolved soon.
Thank you,
Henry
Old Jan 11, 2009 | 03:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Automatic Transmission in lock mode
Did your driveshaft fall out?
Old Jan 11, 2009 | 03:27 PM
hs1322's Avatar
Engine: 350 Carb
Transmission: auto
no its fully intacted.
Old Jan 11, 2009 | 04:01 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Does it have fluid?
Old Jan 11, 2009 | 04:08 PM
hs1322's Avatar
Engine: 350 Carb
Transmission: auto
Fluid is full just checked this morning. Right now tried to put in drive and only making a weird sound not moving. Went shift back into park and made a grinding sound (like shift gears wrong). Right now I have it in park and can roll still.
Old Jan 11, 2009 | 04:18 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Does your speedometer read anything while it's in drive?
Old Jan 11, 2009 | 04:25 PM
hs1322's Avatar
Engine: 350 Carb
Transmission: auto
The needle isn't reading right...it seems to bounce alot...when it worked yestuday...I would push on the gas and it would jump up from 25 to 50 miles per hour...When I was nowhere near that speed yet.
Old Jan 11, 2009 | 04:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What about since you've been having this problem? Is the speedometer moving at all?
Old Jan 11, 2009 | 04:47 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
With car in drive and E-brake set,look under to see if drive
-shaft is turning(sounds like it is since it grinds when put
into park)-if shaft is turning and wheels aren't,spider gears
have broken or fallen out
Old Jan 18, 2009 | 02:46 PM
hs1322's Avatar
Engine: 350 Carb
Transmission: auto
Here's what I have looked into. I put the car rear tires up and they are spinning when car is supposed to be in park. The driveshaft is diffently working, but shift to move forward or in reverse still doesn't. Cable seems to be intacted also.Got any idea's.
Old Jan 18, 2009 | 07:24 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Try this: Jack up 1 rear wheel,leave the other wheel on
the ground-with car in park try to turn the wheel that is
off the ground while observing the driveshaft if wheel can
be turned and driveshaft does not turn there is a spider
gear problem and your axle will need repair.
Old Feb 18, 2009 | 01:41 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
everyone seems to be overlooking the obvious. the engine install. the torque converter probably came out a little and during the engine install when the trans was bolted to the engine it probably broke the pump gears. to check that just pull the plug on the side of the transmission near the shifter(line pressure port) and start the car up. if oil shoots out that is good. if not the pump gears got stacked during install and broke them meaning the trans needs the pump pulled and replaced or repaired. this port will shoot oil out in all ranges regardless as long as the pump works.
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
deracer
Apr 11, 2016 12:04 AM
3tas4me
Sep 4, 2015 01:45 PM
