Clutch release install
Old Jan 11, 2009 | 10:10 PM
JPhillis's Avatar
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
Not trying to run this question in the ground. But I am installing a T5 in my 92 as we speak. I have read multiple swap articles on here using may different phrases and wordings. I have everything but one thing figured out. That would be the wholes needed for the clutch release cylinder. I followed the swap article looking of the imprint in the floor matting or possible knock outs in the firewall, and have neither. My question what is the best way to figure where they need to be. In the area where it needs to go there is very little room for error as we all know. ( measure 3 or 4 times cut once)
Old Jan 12, 2009 | 08:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Clutch release install
when i did mine, the pedal assembly that i installed had 2 rods that came down from the pedal area and rested on the firewall for support, the holes in the rods are the 2 small holes for the masters u-bolt thing. then just cut a oval holes between then using the master as a visual guide.
did that make sense? i could probably dig up a pic if you want.
Old Jan 12, 2009 | 09:57 PM
JPhillis's Avatar
Car: 1992 Camaro
yes that makes perfect sense. My pedal assy had them cut off. I measured 3 or 4 times and thought I had it correct. I found those 2 rods today at a bone yard. I pulled the assy out tonight and installed the 2 rods like they are suppost to be. I have now found my holes are off by about a 1/2 inch to far to the right but I believe I have enough material there for me to redrill and still be sturdy....I HOPE
Old Jan 14, 2009 | 07:57 AM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
That area will take alot of abuse from the pedal. Would it be worth making a little reinforcement after you've got the holes sorted out?
J
Old Jan 14, 2009 | 08:39 PM
JPhillis's Avatar
Car: 1992 Camaro
Guys I got the clutch master cylinder mounted. I lucked out the center hole was fine I just needed to rotate my template that half inch for the mounting holes to line up. But it is going to cost me, sliding out from under the dash I slipped and hit the clutch pedal blowing the end of the slave cylinder out.... WHAT A NIGHT....
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
neekolzun
Aug 24, 2015 04:59 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
smooth
Aug 18, 2015 06:34 PM
rsrmoore
Aug 7, 2015 08:44 PM
