5 peed donor car Q?'s
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
hi everyone..theres a 5speed iroc donor car on the comp for sale for 900(no pics)...but i was woundering if i can swap from an 85 iroc to to a 89 firebird both V8s.....now the problem is that the clutch does not dissengage?...what has failed?..the slave cyclider ETC...im not great with standerd trannys thx bill
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 5 peed donor car Q?'s
yes, all the trans parts will bolt into a bird no problems, the shifter plate on the console will not swap betweena maro and a bird.
if the clutch will not disengage, it could be the clutch master cylinder, the slave, maybe the pushrod fell out, the fork broke ect.
Car: 89 Formy
Transmission: A4
do you think it is worth to buy for 900(i could proli get it cheaper)....to swap over..but somthing is messed up already..hmmm...but i could get alot out of it..
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
$900 sounds high for a parts car. I would talk them way down. I bought a complete '84 Trans Am 305/T5 parts car from a salvage yard for less than half what they're asking for that IROC.
Linson
Aug 21, 2015 02:12 PM
