a big chattering when i start off and shift
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
ok. i have an 82 T/A(mods in my sig) and when i take off and when it shifts there is a big chatter coming from the drivetrain, and it shakes the whole car, and it also slips ALOT. i mean i give it gas and it dont go, well it goes alittle bit. if i were to give it 1/4 gas it takes along time to get to 35mph .It just started a couple days ago. i have a posi 3.23 rear. the car has 151k miles on it. you think maybe its the rear end or posi unit. Thanks
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
New TH350 Raptor with a shift-kit, 2600 stall torque converter, Eldebrock TES Headers, 3" Hooker Cat-Back.
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette 5.7L computer chip, K&Ns, MSD 6A Ignition Box, MSD Conductor Spark Plug Wires .
Audio: JVC Kameleon CD deck, Jenson 4x6 front, Eclipes 6x9 rear, 2 10" mTx T4000 powered by a mTx 200watt amp.
Black Powder Coated 1990 16x8 Formula Wheels with 245/50/ZR16 Perelli P7000.
For Pictures go to
http://members.theglobe.com/RED82TA57L/mycar/
A cool Trans Am site with Message Boards http://www.transamgta.com
RED82TA5.7L
For Pictures go to
Engine: LT1/350 TPI
its not low on fluid, and its only got 1500 miles on it. its a new TH350 Raptor tranny from www.transmissioncenter.net .
RED82TA5.7L
For Pictures go to
RED82TA5.7L
For Pictures go to
Try putting it in Man 1 and taking off. If the chatter goes away that 1500 mile tranny is toast. Check the vaccum at the modulator. It should @18" and when you snap the throttle it must move IMMEDIATELY. It should move as if there is a string attached to the needle from the gas peddle. If it doesn't, pressure rise will be delayed and the trans will have a short life. The good news is that if you liked how it worked at first then you know who to go to to buy another one.
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
push the car around in neutral, see if it chatters. (make sure the car is off the first time, then again with it on) obviouselly if the car is off and its chattering its the rear end. those units are somtimes retarded, and need oil changes just like you engine. (about once ever 75K miles is good however) your rear could definetelly be shot.
Engine: LT1/350 TPI
when i force it in 1st it still vibrates when i take off from a stop. and it seems like the torque converter is slipping ALOT. i think the torque converter could be the problem.
i took the rear cover off the rear end and it looks fine. but that wont tell me anything.
my boss is a mechanic and hes going to look at it soon
Thanks guys
RED82TA5.7L
For Pictures go to
Thanks guys
RED82TA5.7L
For Pictures go to
Transmission: 4l80e
Axle/Gears: 3.512
hmmm a TC causeing THAT? i dunno. wish i knew a little more about rear ends and trannys, but i dont.
Well of course it doesn't go fast when you give it 1/4 throttle. You have a 2600 rpm stall with 3.23 gears. As for the chatter, tell your passenger to shut up!!! ( a little humor)
Rear ends make a LOT of noise when they break. But they make noise at all rpm when you break a ring gear. If you power-break the car, what happens?? Is your stall speed the same??
If it chatters then its your trans. Have you checked all mounts and flexplate bolts???
What were you doing when the trouble started?
High stall, low gears = heat (and lots of it)
Look at the converter, if the paint is burned off, everything is toast. I hope you have a trans cooler on that thing.
You don't have a bad brake shoe, or maybe left the parking break on?? (just kidding)
Hope this helps.
Hope this helps.
Engine: LT1/350 TPI
it doesnt make any noise. so it must not be the rear end.
i took the driveshaft off and the joints were very very loose. i mean you lift up the thing that goes into the tranny and it drops. you think that that could do all that vibration. and i do have a tranny cooler on it. and the paint is still on the converter
and if i gave it 1/4 gas before this started it would get up to speed. but now it seems like it dont want to go.
since i thought the joints on the driveshaft were too loose i brang it to All parts to have the driveshaft rebuilt and balanced.
Thanks for all your help..
RED82TA5.7L
For Pictures go to
RED82TA5.7L
For Pictures go to
dhonda200
Aug 11, 2015 11:50 PM
