Lock up convertor diagram
Old Apr 22, 2001 | 02:31 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
I'm having problems with my 700r4 not locking properly.Ive tried loads of things but still not cured.Can anybody tell me the exact route the fluid should take when in lock up or even better has anybody got a picture or diagram showing it.
powermite
Old Apr 22, 2001 | 10:29 PM
need4speed's Avatar
Well it doesn't go very far.... (he,he)
Seriously, what did you do before it quit working??
The oil path for the tcc release doesn't go very far. There are only a few things that would cause it not to work. Only one of them can be fixed without pulling the trans.
If you are positive the electrical works, and the solenoid coil isn't "open". The solenoid may have a crack , dirt in the orifice checkball capsule ,bad checkball or o-ring seal (it works by exhaust). A sticking tcc valve will do it also. It is just above the solenoid in the pump housing.
If not it could be the teflon seal on the input shaft, or the o-ring on the end of the input shaft. Or you may have burned up the lining inside the converter.
To apply the tcc clutch, the exhaust valve on the solenoid closes, the tcc valve moves up, oil pressure is the routed through the pump, to the input shaft, out the very end of the input shaft into the converter.
Hope this helps.
Old Apr 22, 2001 | 10:52 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
What year tranny? Let me know and I will scan and email you the hydraulic schematic.
Old Apr 23, 2001 | 12:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Old Apr 24, 2001 | 12:01 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Ummm... he beat me to it.
Old Apr 24, 2001 | 01:35 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Sorry, man.. already had it on the computer.
InfernalVortex
Apr 20, 2021 11:31 AM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
