need a 700r4 input shaft measurement
Old Jan 17, 2009 | 05:18 PM
project89's Avatar
i need to know if the v8 30 spline input shaft is the same lenght as the small bellhousing v6 27 spline shaft
reason i ask is in order to step up to a multi disk lockup converter to have lockup capabilitys under wot,i need the 30 spline shaft.but i was told there is a length difference between the v6 27 spline and the v8 30 spline shafts
can anyone get me a measurement of the 2 diff shafts?
Old Jan 19, 2009 | 03:58 PM
project89's Avatar
Re: need a 700r4 input shaft measurement
anyone?
Old Jan 26, 2009 | 11:13 AM
project89's Avatar
bump
Old Jan 26, 2009 | 03:29 PM
Shagwell's Avatar
Car: projects.......
Re: need a 700r4 inout shaft measurement
I'll try to remember to check this when I get home. I only have one v6 trans and it is a 27 spline. It's still assembled, but I can get it's length from the pump vs the later/V8 30 spline from the the pump.
Old Jan 26, 2009 | 04:04 PM
project89's Avatar
thnx man, i assume that is were the difference would be if any at all since the internals are supposed to be identical.
Old Jan 29, 2009 | 02:11 PM
project89's Avatar
anychance u got to measure that shaft for me??
Old Jan 30, 2009 | 01:11 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
I measured a 30 spline v.8. from a 1989 and found it to be approx 4 inches from the converter seal to the end of the input shaft. hope anything helps. Don't have a 6 cyl to compare to. I'll provide more-just pm message me if I forget to check back.
Old Jan 30, 2009 | 01:15 AM
project89's Avatar
thnx man, ill check it against my spare v6 trans and see if they match up
87v6Bird
Jul 1, 2018 04:12 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
HikoriYami
Sep 21, 2015 07:11 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
tonys91rs
Sep 2, 2015 07:07 PM
