Double Clutching it
Old Apr 20, 2001 | 12:48 PM
Jason 85 IrocZ's Avatar
Double Clutching it
Hello
I was curious I have a 1991 RS with a 5-speed.
Is it nessessary to double clutch when going from a high gear to the next lowest gear??
Or is it just a good idea to do it.
Jamieson
85 Blue Super Charged Iroc-Z28 Camaro
79 TransAm
1991 RS
1999 Oklahoma Gathering
2000 SWMG
Old Apr 20, 2001 | 01:31 PM
FormulaJoe's Avatar
I dont see why it would be necessary. The transmission is synchronized, so why bother?
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
Old Apr 20, 2001 | 06:08 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Real old cars had straight cut gears and you had to double clutch up and down the gear box.
Synchro was developed to elimiate the need to double clutch. The gears are cut at an angle and it uses synchro rings or cones to mesh the gears at the same speed. So there is no reason to double clutch these unless there's something wrong with the trans.
If you want try something with shifting though, learn to heel and toe your downshifts. It takes a bit of practice but it's really cool when you get it right.
Old Apr 20, 2001 | 08:00 PM
OLDYELLR's Avatar
Car: '85 IROC
You can double clutch if the synchros are worn out, which happens eventually. I just do it sometimes out of force of habit, especially going down into 1st gear, because synchromesh on 1st didn't exist on any car I could afford when I started driving. I drove a few British sports cars, which couldn't keep synchros for more than a couple of years.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old Apr 23, 2001 | 03:39 PM
FormulaJoe's Avatar
What exactly is meant by "heel and toe". Ive heard this several times but dont know what it means. Please elaborate. Thanks.
Old Apr 24, 2001 | 08:04 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
It's a way to brake and downshift at the same time so that you can leave your braking point a lot later than someone who has to take their foot of the brake to operate the clutch so that they can downshift to the gear they're going to need for driving around the corner and coming out of it.
So, you keep you left foot on the brake and downshift by declutching with the left side of your right foot (toe), making your gear change and then matching the revs for the downshift by using the right side of your left foot (heel) to blip the throttle as you let out the clutch. Remember to ease off the brakes a bit as the lower gear engages otherwise you might lock up the rears and spin.
You don't exactly use your heel or toe but that's what it's called.
The way the peddles are set up on an f-body it also helps to have big feet.
Sorry about writing a book but I could'nt make it any shorter and still explain it.
Old Apr 24, 2001 | 08:27 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
I just read that and realized that's it's totally *** backwards.
Sorry, I was trying to keep it short and not thinking about what I was saying.
Everything is as I've said except the obvious mistake being that I've got the clutch and the brake in the wrong place.
So, brake using the left side of your foot, declutch and downshift normaly, match the revs by blipping the throttle with the right side of your foot while still braking.
Old Apr 25, 2001 | 10:32 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
Heel & Toeing can be done if your feet are big enough by using your left foot on the clutch and putting the ball of your right foot on the brake and rolling the rest of your right foot over to match or bring up the revs before releasing the clutch. Pratice when driving on the streets (CAREFULLY PLEASE) and then apply on the Autocross tracks. Works great and feels fluid once mastered.
Iroc Z28 with several mods for domination of autocross courses.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
mfp189
Sep 27, 2015 09:25 AM
