New 700r4 Install
Old Apr 26, 2001 | 12:58 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
New 700r4 Install
Hey just got my new 700 back and getting ready to put it in, I am using the B&M Holeshot 2400 and am wondering do I fill the torque converter with tranny fluid and how much. Is there any other tips you guys can give me (thins is my first time)
Brian Felts
Old Apr 26, 2001 | 01:31 PM
Pro Built Automatics's Avatar
Put one quart in as you do not want the TC to start dry. Put 4 quarts in the transmission itself before starting and add fluid as fast as possible till you get to 10 quarts then start reading the dipstick (read both sides, the side that reads the lowest is the true reading) keep adding fluid till full. Check the TV cable to be sure it is adjusted properly. Drive easy first 5-10 miles, recheck fluid level. Now you will be ready to try some 1/2 - 3/4 throttle upshifts to see if everything is correct, if ok go for a pass & see what happens.
Hope This Helps!!!
Old Apr 26, 2001 | 01:44 PM
IROC KID's Avatar
i couldn't have said it better myself,just take it easy with her at first and when you install the tc snug each bolt one at a time and turn it and repeat it until they are all tight,dont tighten one all the way and move to the next one as you want it to line up correctly and flush,just a tip,also make sure the tc goes on the splines correctly and clicks 3 times when you spin it,but i am sure you already know that.
camaro11j
Sep 19, 2018 08:49 AM
formula_novice
Aug 18, 2015 08:48 PM
TreDeClaw
Aug 14, 2015 06:58 PM
fonzie85
Aug 13, 2015 11:50 AM
drathaar907
Aug 6, 2015 04:20 PM
