26 or 28 spline?
Old Jan 20, 2009 | 02:39 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
26 or 28 spline?
Question:
Are all Camaros & Firebirds 10 bolt factory rears come standard with 26 spline.
Or do some come factory with 28 spline. And is there an easy way to tell?
Old Jan 20, 2009 | 03:18 PM
thenjoshsays's Avatar
Car: 92 RS
Engine: 305 TBI
Axle/Gears: 4th Gen/3.23/Posi
Re: 26 or 28 spline?
From all I've seen, all the 90-92 rear ends came with 28 spline axles. A few 89's had them, but they were the exception and only those at the very end of the year's run...
Old Jan 20, 2009 | 07:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Although a previous owner could have easily upgraded a 82-89 to 28 spline axles. The only way to know for sure is to pull the axles and count the splines.
Old Jan 20, 2009 | 09:02 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you're asking about your '88 rear end, its going to be a 26 spline if its a 10-bolt.
9-bolt rear ends have 28 spline axles, and '90 and newer 10-bolts have 28 splines also.
Old Jan 20, 2009 | 09:06 PM
Car: 1988 IROC-Z28
Thanks for the info. guys.
As far as my rearend goes its actually from a Firebird a 3:73 10 bolt, but I don't know what year the car was it came off.
Old Jan 21, 2009 | 08:53 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
[QUOTE=Americanmouse;4015437]Thanks for the info. guys.
As far as my rearend goes its actually from a Firebird a 3:73 10 bolt, but I don't know what year the car was it came off.[/QUOT
If it is a stock 3:73 it is from a pre 85 model is sure to have 26 spline axle shafts.
Old Jan 21, 2009 | 09:15 AM
Car: 1988 IROC-Z28
As far as I know the guts are stock, although I did crack it open when I got it, and the gear teeth had a nice edge to them at the time. And yes it came directly off the Firebird, as the owner at the time said he'd swap my 9 inch 2:73 for his 10 bolt 3:73. He said he wanted better economy rearend.
Thanks again everyone!
Old Jan 21, 2009 | 03:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You probably mean your 9 bolt 2.77 for his 10 bolt 3.73
codeysabatini
Nov 10, 2015 04:07 PM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
Numbah-1
Sep 20, 2015 09:31 AM
Prodigious
Sep 18, 2015 05:23 AM
