Can't get input assembly out!
Old May 2, 2001 | 09:31 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
This is actually on a 4L60E, but I understand that it is the same. The input shaft and clutch assembly won't come out! The manual I have says it should come right out (although the book is for a 700, not 4L60E) Is something messed up in there, or something? Is this a common thing?
The trans is coming apart because it lost 3rd and 4th (3-4 clutch pack, man the fluid was dark!)
Thanks in advance!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old May 3, 2001 | 05:51 AM
Pro Built Automatics's Avatar
Did you remove the 1-2 apply servo on the side of the transmission? If not, most likley to not come out.
Old May 3, 2001 | 12:14 PM
JP84Z430HP's Avatar
Car: 84 Z28
Yeah, I have the band and the first drum out, but I can't get the one out that the input shaft connects to. I have now been told that either the planetaries are broken, or the clutches are seized together, so I just need to use some brute force.
Thanks.
Old May 3, 2001 | 02:23 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Try twisting it rapidly while lifting. It supposed to come right out...
Old May 3, 2001 | 07:19 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Once the band is out of the way, the input housing should lift straight up, even if the "first drum" (reverse input housing) still in there or not. Sounds like something is damaged and either "welded" itself together, or just got stuck.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Old May 3, 2001 | 09:05 PM
JP84Z430HP's Avatar
Car: 84 Z28
Well, I got it out. It was the infamous 3-4 clutch pack that had welded itself together. It took a strategically placed prybar and someone tugging just the right way on the input shaft.
This transmission seems to be pretty simple as far as rebuilding goes. It's MUCH easier than Chrysler's A-604!
I'm now having problems with the 3-4 clutch pack going back together. The kit I got has the thicker steels, but not the revised retainer plate (I forget exactly what it's called, but the plate that goes on last under the snap ring)
Thanks for replying!
cheesehomer
Dec 31, 2015 08:48 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Oct 3, 2015 01:25 PM
Linson
Oct 1, 2015 09:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
