swap 700R4 to TH 350
Old May 3, 2001 | 10:11 PM
quest for 12sec..92RS's Avatar
Hey guys I'm new to the boards but I was wondering what you guys thought about swapping a 700 for a 350. I am running a 383 with around 400 to 450hp in my 92 camaro and I burnt the 3-4 clutches up in the 700. I have talked to a few rebuilders and they have different opinions about the 700. I was wondering what you guys thought about rebuilding the 700 or swapping to the 350. The car is driven quite a bit on the street but also bracket raced. Thanks
Old May 3, 2001 | 10:26 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Wow! A first post! Welcome!
If you drive it much at all on the street, and fuel mileage is of any concern, which we all are now! I'd reccomend building a 700. The other guys can give you more details, but there are several things you can do to make a 700 nearly bulletproof. That's what I'm gonna do for my ZZ430.
Good Luck!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
xkingcodex
Feb 12, 2020 07:43 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
camaro11j
Sep 19, 2018 08:49 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
