why cant i shift?
Old Apr 30, 2001 | 09:18 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
why cant i shift?
i have an 86 z28 w/305 4bbl. when i bought the car it had a new trany. but now i find out its not an oem trany but a different kind. it is very hard to put the car into 1st and 2nd gear. its impossible to. i have to pump the clutch 6 or 7 times for it to slide into gear just nice. how can i solve this problem? thanks
Old May 3, 2001 | 06:13 PM
transfixleo's Avatar
Adjust/replace the clutch.
Old May 3, 2001 | 11:16 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
<font face="Verdana, Arial" size="2">Originally posted by z28crazy:
i have an 86 z28 w/305 4bbl. when i bought the car it had a new trany. but now i find out its not an oem trany but a different kind. it is very hard to put the car into 1st and 2nd gear. its impossible to. i have to pump the clutch 6 or 7 times for it to slide into gear just nice. how can i solve this problem? thanks</font>
If you have the hydraulic "linkage" you may have to replace the master or slave cylinder. Check for leaks and stuff. Bleed the system. Pumping it 6-7 times sounds like it may be leaking or have air in the system. Or the master cylinder might be leaking past the piston seal, which means replacement.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
