NOT Third gen*** 3.4l v6 manual transmission code
Old Feb 3, 2009 | 12:19 PM
Snikker's Avatar
Car: 1998 Pontiac Firebird Trans-Am
Engine: Ls1 Modified intake magnaflow duals
Transmission: 6spd Manual
Axle/Gears: Stock
Forgive my ignorance, seeing as I own a fourth gen I should probably know this, but what transmission was the available 5 speed with o/d that came as standard for the '94 3.4l v6? (specifically what number designation ie 4l60e etc was it) I just miss having a clutch underfoot and being able to force the d*** thing to stay in what gear I want it in. if I do complete the swap i plan on getting the skip-shift eliminator from somewhere like SUMMIT or JEGs, so that wont be too much of a concern.
I do feel kinda dumb for not knowing this, I do like to at least consider myself a somewhat knowledgeable person when it comes to cars?...?...
Old Feb 3, 2009 | 01:28 PM
big gear head's Avatar
Re: NOT Third gen*** 3.4l v6 manual transmission code
The manual transmission was a Borg Warner T-5. This had the Mustang bolt pattern on the case. It's different from the T-5 that was used in the 3rd gen cars. I left one sitting on the ground when I bought the 3.4 that I'm using.
I know exactly what you mean about putting it in the gear that you want instead of whatever gear it feels like being in.
LarryD
May 8, 2014 02:19 PM
OdieTurbo
Nov 24, 2011 06:48 PM
94Camaro
Jan 26, 2006 08:21 PM
Pillsbry10
Aug 5, 2003 06:26 AM
