Makes bang in reverse.
Old May 10, 2001 | 12:03 AM
KW87GTA's Avatar
Hi, I have an 87 700 and a Ford 9 rear from Moser, and a B&M shift kit. When I put the car in reverse using the rachet shifter, the car makes a loud clunk. I know the rear setup backlash is a little off, and have been meaning to fix it, but what else could be causing this clunk? Thanks.
87 GTA 350 L98
K&N filter, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Gutted cat, removed emissions, Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed TB coolant, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
Old May 10, 2001 | 07:45 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Possibly what you mentioned, or bad u-joints, or the fact that 87 transmissions didn't have the smoothest shift out of park could be some causes.
Hope this helps at all, but some early transmissions did some hard-*** shifts out of park.
Old May 10, 2001 | 11:35 AM
purpleworm's Avatar
My 84 would beat your head off the dash soemtimes!! I think you just have to put up with it. My 91 is a lot better.
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit 3.42 rearend
One sweet sounding system
camaro11j
Sep 19, 2018 08:49 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Ozone
Aug 29, 2015 08:19 PM
mizz0313
Aug 12, 2015 06:45 AM
hokis
Aug 9, 2015 03:57 PM
