Will this 700r4 work in my car
Old Feb 9, 2009 | 09:44 PM
thekevin's Avatar
Car: 1985 Z28
Axle/Gears: 3.23 open
I picked up a 700r4 from an 86 Suburban 2wd, is there anything I need to do other than swap out the tail section to make it work. On the converter, how much difference will there be in the converter that came with and what came with my car factory, my trans is making all kinds of racket so I dont want to use my converter but I'm not against buying a new stock converter if needed.
Old Feb 10, 2009 | 12:22 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Will this 700r4 work in my car
Should work fine-i use one from an'85 caprice in mine
(with shift kit/servo upgrade) the suburban converter
might have different stall speed,but maybe not since
a lot of 2wd suburbans had 305s.I like to use good
aftermarket converters for the greater durability of the
furnace brazed fins.
Old Feb 10, 2009 | 12:31 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
you need to do a spline count-transmission to transmission on the input shafts, that way you know what you've got. the 85 will be a 27 spline and the 86 will be either a 27 or 30 depending on the build date of the unit. these factors determine torque converter selection as the converters don't interchange.
Old Feb 10, 2009 | 07:07 AM
thekevin's Avatar
Car: 1985 Z28
Will both of them have the 4 pin converter lockup plug.
Old Feb 11, 2009 | 12:03 AM
ed o's Avatar
Axle/Gears: 3.36
yes/both four pins.
don't forget to change your speedo gear on the output shaft if it is different, and the driven speedo gear. You might also need to retain your governor as it was calibrated for car gearing v.s. truck gearing. Just some random thoughts.
Terrell351
Jun 13, 2021 01:13 PM
fonzie85
Aug 13, 2015 11:50 AM
drathaar907
Aug 6, 2015 04:20 PM
Leggman1
Aug 6, 2015 04:15 AM
