HELP! Tranny and/or rear end messed up? HELP!
Car: 1992 Camaro RS Convertible
Axle/Gears: LS1 posi/disk 3.42
hey guys, heres the problem....... when i am at a complete stop and give my car half throttle or more..... i here a clunk type sound coming from my transmission area. sometimes its there sometimes its not, on a side note i here sometimes the same clunk from my rear end. its hard to really hear exactly where tho since my exhaust is really loud. headers-custom y-pipe-single chamber flowmaster dumped under passeger door
i have a shift kit installed in the trans... been in since june/july.... not exactly sure. i also just installed a torsen diff with gm 3.42 gears about a month ago. everything was fine and the car felt great alto i thought i detected a hint of gear whine. didnt pay to much attention since its been stated on here often that they do that some. then about a week ago i had an extra throttle body from my 93' silverado. i did the untimate TBI mods to it and put it in place of the stocker. it didnt have a *** for the t.v. cable so i fabed one up. well the spot for the t.v. cable ended up being about and inch farther away than stock, so i just adjusted the tv cable. after that the shifts were super firm and about 2 days after that i herd the click/clunk noise. it doesnt do it tho when i cruise/baby it, only hard acceration from a stop/crawl in 1st gear and hard downshifts from 2/3 gear to 1st gear. basically when peak torque is applied i guess.
any ideas or suggestions would be greatly appreciated. i am assuming that maybe the torque converter craped out or the rear end needs to be reset or both. sorry for the long post, but hopefully someone can guide me in the right direction.
Re: HELP! Tranny and/or rear end messed up? HELP!
I'd say that it is a transmission problem, but here are some things to check. Check the u joints first. Then check the pinion. It is not uncommon for the pinion nut to loosen up and allow the pinion bearings to become loose. Hold the pinion yoke and see if you can push it up and down or in and out. If you can then you need to get it fixed right now. I say this because you mentioned that you can hear a little gear noise.
thanks for that info.... i'll look into the u-joints and pinion this weekend... hopefully thats all it is but with my luck it probably will be something expensive
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I would first check the transmission cross member. There is a mount that always seems to go out and it seems like from your description, that may be your problem.
thanks a bunch for those ideas guys, i'll be sure to check them all tomorrow.... hopefully it will only be the trans mount or a u joint.... gota make the income tax check last!
Edit: do any local auto parts stores sell polly mounts? i looked on autozone and says its special order. also what would be the benifit of the poly mount vs. a standard rubber mount? stiffer/stronger???
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
don't forget to check the torque arm mount bushing also
Car: 1989 firebird
Engine: 383
Transmission: 6 speed
Axle/Gears: ford 9" 410
transmission mount is bbroke and the trans is lifting up and hitin the car,,,, not a big deal had it on a car for years.... it wont look broke but get a jack and jack on the trans and you will see... easy fix..
and thanks again for all the replys and suggestions, i knew there was a reason i always visit the site. TGO rocks
just incase anyone was wondering, my trans mount was completely broke. i installed a poly mount and all is good
1 Post
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Well all's well that end's well.
Consider coming up to the Houston meet in July.
Check out the regional board for more details.
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
