Th 400 drive shaft
Old Feb 12, 2009 | 09:19 PM
84 camaro z28's Avatar
Car: 84 camaro z28
Engine: 5.7 carbed
Transmission: turbo 350
Th 400 drive shaft
I orginally had a th 350 but I blew it up so i switched to the th400 but the question is how long of drive shaft do i need. The th400 is 2 1/2 inches shorter then the 350 so I dont know what I would need and wheres a good store to buy it.
THanks
Old Feb 12, 2009 | 09:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Th 400 drive shaft
Shorter? A TH400 is one of the longest non OD transmission.
Read this
http://www.chevyhiperformance.com/te...ech/index.html
Old Feb 13, 2009 | 11:25 AM
Car: 84 camaro z28
Engine: 5.7 carbed
We measured the case of the th 350 and 400 and the cases were 2 1/2 inches shorter. The th 400 only had like a 3 in slip yoke so that could of been the problem.
Old Feb 13, 2009 | 12:14 PM
Shagwell's Avatar
Car: projects.......
Unless you had a really long tail 350 it shouldn't have been longer than a 400.
Anyhow, you will also need a different yoke, as the Th400 has a larger output shaft. Your best option is to get the proper yoke, put in in the trans(slid out just under 3/4" from bottoming) and measure from the center of where the u-joint cap is to the center of the u-joint cap on the differential.
There is probably a comon length listed in the th400 parts sticky, but there are definitely some variances in the construction on these cars.
Old Feb 17, 2009 | 10:36 PM
Car: 84 camaro z28
Engine: 5.7 carbed
Well we have the shortest tail on the th400 and we are thinking about going with an external slip, Any ideas on this?
Old Feb 17, 2009 | 11:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Not a good choice. Buy a proper slip yoke and make a solid driveshaft.
Old Feb 17, 2009 | 11:39 PM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
ditto
Old Feb 18, 2009 | 01:21 PM
Shagwell's Avatar
Definitely stay away from the remote slip joint. Unless you have a 4wd output(won't have a tailhousing) then you should have no issue running a regular slip yoke. Even the bolt-on yoke output shaft will accept a slip yoke.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
Ozz1967
Aug 16, 2015 10:23 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
