PLEASE help me identify this rear!!!
Old May 18, 2001 | 12:15 AM
Zio's Avatar
Zio
Hey guys right now i have a open 2.73 rear and it sucks. I found a rear for sale that the guys say has 3.73s in it. He also stated that someone told him that it might have 4.11s in it. he gave me some numbers off the rear i don't know if they will tell what gear it is or not. could you guys help me out or point me in the right direction.
Here are the numbers or code:22511175n and gm3k.
thanks
Tom
Old May 18, 2001 | 10:33 PM
transfixleo's Avatar
The fool proof way to find out is this. Mark both wheels/drums/whatever. Now mark the driveshaft yoke. Turn the wheels at the same time, counting the number of times the yoke goes around including 1/4 turns. If it turns a little over four times for one full turn of the tires then you do have 4:11's. If it is @3&3/4 turns you have 3.73's and so on.
Old May 19, 2001 | 12:41 AM
Zio's Avatar
Zio
transfixleo thanks for your help. I would do that if it wasn't over a 100 miles from my house. i can't afford to drive that far and not buy the rear. i am going to ask the man selling it if he can use your method.
thanks
Tom
Old May 20, 2001 | 10:17 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Are those numbers off the center pumpkin? If so, they're not going to help. The numbers you need are on the passenger side's axle tube, facing the "front" of the car. You'll need a wire brush to dig them out of the dirt & rust. The numbers are separated into groups, as in "### # ##### etc" .. you want the first 3-digit code. That's the axle code that tells you the gears & if there was a posi or not.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old May 20, 2001 | 05:17 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The axle code only tells you what gears were originally in it, and wont help if they've been changed. The only way to know for sure is transfixleo's method.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
hectre13
Dec 11, 2023 08:14 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Redwhisper
Aug 26, 2015 05:02 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
