to repair a a V-8 T5 with parts from a v-6 t5 ?
Old May 18, 2001 | 11:37 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
to repair or not to repair "that is the question" (w. shakespiare)
now for real, i have to repair my T5 V8 and all i have is a t5 v6 tranny, both are nwc.
the input shaft are diferent but everything else seems the same,
did somebody ever try this crazy thing? i have no money thats why i'm trying this "crazy" option, i also taught abaut using mobil jet oil to experiment.
turbine oils are synthetic and very resistent to enormous heat and pressures (like any jet engine)
please think about before calling me crazy.
thanks to all...
fernando
third gen muscle power is the only thing that can match the power of flight...
Old May 18, 2001 | 12:27 PM
PonchoTA's Avatar
Most parts will interchange but the gear ratios are totally different. Because the V6 has so much less power, the ratios are different to take advantage of what is there.
I just tried to change OD gears from a V6 to V8 T5 and the inner diameters of the gears were different, so the output shaft was of a diff. diameter at that spot, and it didn't work.
Rotsa ruck.
Old May 20, 2001 | 05:52 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You'll pretty much have to swap all the guts from the V8 unit into the V6 case; only the bearings, seals, and shifting mechanism are the same.
I'm running my 83's original V6 case with V8 internals from my old 84Z transmission.
Pete
Pete's Place
HiOutput Tech Page
<a href="http://www.hioutput.com/pete/garage/83SC/83sc.html" TARGET=_blank><IMG SRC="http://www.hioutput.com/pics/SC.gif" TITLE="Pete's 83 SC" border="1"></a>
My 83 SC...(originally V6) 208,100 mile LG4/5-speed from an 84 Z28, 3.42 one-tire-fryer, T-tops, PW, PH, boxed LCA's, Hedman Hedders and y-pipe, Dynomax cat-back, .420" lift cam, custom air induction .....best ET is 14.935@94.14</P>
</P>Success means you got up one more time than you fell....
F.I. 57 Belair
Aug 23, 2021 01:09 AM
gta892000
Aug 11, 2019 11:16 AM
Elephantismo
Feb 13, 2019 12:51 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
75bike
Sep 20, 2015 09:37 PM
