Tools for 700 rebuild
Old Apr 30, 2001 | 10:31 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Ok, I'm getting into automatic transmission rebuilds at work, and so far have only needed to do Chrysler, and Mitsubishi transmissions. I hear that some of them that I have done are the hardest ones out there. I didn't think it was all that bad.
Now, I'm planning to build my own transmission for my car, and we have one in needing a rebuild right now, so I just would like to know what tools are needed. Any other advice for assembly, and things to look for would be appreciated!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old May 1, 2001 | 06:56 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
J-21366 converter holding strap
J-21386 oil pump alignment band
J-21426 output shaft sleeve oil seal installer
J-21427-01 speedo gear puller
J-2269-01 servo piston compressor
J-23129 converter housing seal remover
J-23327 low/reverse clutch spring compressor
J-23456 clutch spring compressor press
J-24773-A input clutch spring compressor adapter
J-25022 end play fixture adapter
J-29714-A servo cover compressor
J-29837 output shaft support fixture
J-29882 overrun clutch seal protector
J-29883 forward clutch seal protector
J-33037 intermediate band apply pin guage
J-34196-A bushing service set
J-34627 snap ring pliers
J-36352 speed sensor rotor installer
J-36418-A turbine shaft seal installer
J-37789-A oil pump remover/installer (91 up)
J-38119 rear extention bushing remover/installer
J-38417 speed sensor remover (for trucks only)
J-39119 oil pump remover/installer adapter (91 up)
Will anyone ever buy all these? Most of them are overpriced junk.
I rebuilt mine completly: every piece removed, inspected, repaired/replaced, and reassembled without using any special tools, and doing it correctly. I admit I used c-clamps, servo housing, pitman arm puller, hose clamps and a bunch of plastic dixie cups as special tools... And a dial indicator, feeler guages of course.
You could buy and price these tools online at http://www.spxkentmoore.com/ but when you see the prices your going to sh:t a brick!
You could probably buy 5 remanufactured transmissions cheaper than the tools to rebuild one.
Old May 1, 2001 | 09:22 PM
JP84Z430HP's Avatar
Car: 84 Z28
Thanks for the info! I suppose that some of the tools I have already made to work for the Mopar tranny's (clutch spring compressor, etc....) may be all that I need. Fortunately, I'm gonna have one to play around with, as the customer needs it ASAP (don't they always) and we can get them a used one pretty fast. I'll get to keep the core (broken 4WD case) to play with to figure out what I'm doing, and I can make the tools that I need, before I actually NEED them.
One thing I think I might get will be the pump alignment band, and the servo compressors may be handy, too. I have put pumps together without the band and pin with no problem before, but I think the tools would make it nice.
I also think some of the tools get in the way (at least some of them for Mopar's have) so I will figure it all out when I get one apart.
If anyone else has anything to add, please do!
Thanks!
Working on:
145 MPH IROC Speedo
Old May 1, 2001 | 09:33 PM
Nordbert's Avatar
Get an ATSG rebuild manual for your transmission and study it carefully before teardown. Most operations requiring special
tools, such as installing the teflon rings on the input shaft, can be done by a local
rebuild shop for a reasonable price. As Joel
said, most transmission tools are very expensive. Because of this, I have made most of mine.
Old May 2, 2001 | 06:44 AM
JoelOl75's Avatar
Don't bother with that special tool....
Just rebuild your pump before you start putting stuff back into the case and stick it in the case upside down (less the o-ring) and align the holes with a bolt or something. Tighten the bolts up and pop it out... Perfectly aligned!
Old May 2, 2001 | 08:57 PM
JP84Z430HP's Avatar
Car: 84 Z28
I have also been making my own tools. Big money saver, especially since I have access to the equipment I need to make them (Mill, lathe, welder, etc....) ANd, yes, they are expensive!
I really don't like the idea of taking stuff to a tranny shop, because the only local one sucks, and the shop I work for is sort of competition for them (we do everything, the do just tranny's)
I never thought to put the pump in backwards! Great idea!
Working on:
145 MPH IROC Speedo
Old May 3, 2001 | 09:13 PM
JP84Z430HP's Avatar
Car: 84 Z28
Thanks for the help guys! I have the first one almost done! I just need to make another tool in the morning to get the Lo-Reverse piston return spring compressed. If anyone has the tool handy, could you please measure the Inside and outside diameters of the part that contacts the spring retainer? If I don't hear anything, I'm gonna go with 3.25 I.D. and 4.00 O.D..
Thanks for the tip on the ATSG manuals. Nice book! Very detailed! I'm gonna get one for every tranny that I do from now on! It just so happens that the shop I get rebuild kits and conmvertors from carries them. They also carry the Trans-Go recalibration kits! :-)
Thanks for all the help!
Old May 20, 2001 | 10:54 PM
chillz's Avatar
www.trannyman.com has the few tools you may need, and a bit less expensive than kent moore..
Old May 20, 2001 | 11:06 PM
JP84Z430HP's Avatar
Car: 84 Z28
Thanks! I'll check that one out!
The main thing I need now, is the seal tool. The one that's like a feeler gauge, or the one that's like a loop of wire. I have made all the spring compressors that I think I need, and they have worked for the Chrysler tranny's that I've done, too (That's what I've made them for, as they seem to be really weak tranny's!)
Anyone know of any other good transmission web sites? I have been to a few.
Tahnks again!
Working on:
145 MPH IROC Speedo
Old May 21, 2001 | 08:49 PM
JoelOl75's Avatar
From what I understand on these is there are two types... One is a wire loop on a stick and the other one is just a feeler guage mounted on a long handle...
I got away with just using a feeler guage.
Old May 21, 2001 | 09:09 PM
JP84Z430HP's Avatar
Car: 84 Z28
Well, I didn't have much luck with the feeler gauge on the reverse clutch piston seal. It took me forever to get it in there! For the most part, the others went in ok. I can also use them on some of the other transmissions that I do (GM, Mopar, Ford, Imports, etc.....)
Working on:
145 MPH IROC Speedo
92projectcamaro
Dec 8, 2015 12:25 AM
Reid Fleming
Oct 10, 2015 09:56 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
