Retrofit 7 vane to 13 vane?
Old Mar 29, 2001 | 05:34 AM
BV's Avatar
BV
There is a kit to change a 10 to 13 vane pump. Will this work on a 7 vane pump? Thanks.
Old Mar 29, 2001 | 05:52 AM
Pro Built Automatics's Avatar
The 10-vane pump is more than enough for any performance application. Changing to a 13-vane pump is a total waste of time, the reason for the 13-vane pump is it runs quieter, it does not flow more oil, in fact the 7-vane pump when set up correctly flows the most!
Hope this helps!!!
Old May 21, 2001 | 11:44 PM
racerRoy's Avatar
you can use any amount of vanes you want. 10 is plenty but you need to use the right pump slide springs. get a transgo pump ring kit
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
anesthes
Sep 18, 2015 12:34 PM
apie2546
Sep 4, 2015 03:47 PM
TreDeClaw
Aug 14, 2015 06:58 PM
mustangman65_79
Aug 11, 2015 03:17 PM
