Rear end fluid change
Old Feb 17, 2009 | 10:58 AM
GTA BANDIT's Avatar
Car: 1991 Trans Am Gta
Engine: 350 Tpi
i have a 1991 trans am gta. i want to change the rear end diff fluid soon. what should i use? and do i have to use any special additives?
Old Feb 17, 2009 | 11:12 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Rear end fluid change
Have a limited slip rear end? The safe thing to suggest is to purchase a bottle of GM limited slip additive and three bottles of GL-5 replacement fluid. You can save some money on the oil if you shop around but, I would strongly suggest that you stick with dino oils and not go the other route and blow lots of coin on the synthetics.
Old Feb 17, 2009 | 11:22 AM
GTA BANDIT's Avatar
Engine: 350 Tpi
it leaves two tire marks so i guess its a posi traction but that is the same as limited slip right? where can i get that additive you were talkin about
Old Feb 17, 2009 | 11:48 AM
PURPLEFORMULA's Avatar
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
Most autoparts stores have the additive but if not you can get it at the dealership.
Eric
Old Feb 17, 2009 | 11:50 AM
GTA BANDIT's Avatar
Engine: 350 Tpi
ok cool! is it easy to change the rear end fluid? from looking under the car it looked like there was a bar in front of it
Old Feb 17, 2009 | 11:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You'll have to pop the diff cover to change the fluid, so take note if your car is equipped with limited slip (GM's name for the posi). If it is, use GM’s limited slip additive, P/N 1052358. Your dealership will have it in stock. The sway bar will drop when you jack the car up. Check the first pic in the following link (there's also a pic of an Auburn limited slip down a bit):
https://www.thirdgen.org/forums/tran...ing-axles.html
JamesC
Old Feb 17, 2009 | 11:58 AM
GTA BANDIT's Avatar
Engine: 350 Tpi
awsome sounds easy! thanks man. how much gear oil should i use? and what weight would u reccomend?
Old Feb 17, 2009 | 12:07 PM
JamesC's Avatar
Easy, but messy. You'll need to button up with a gasket or RTV before you refill. I use Mobil 1 LS gear lube, 75-90, with GM additive. I'm unsure what the manual calls for. Wade says three bottles, which sounds right.
JamesC
Old Feb 17, 2009 | 12:09 PM
GTA BANDIT's Avatar
Engine: 350 Tpi
what do you mean button up with a gasket or rtv?
Old Feb 17, 2009 | 12:16 PM
JamesC's Avatar
You'll need to place a bead of RTV around the diff housing or use a gasket in its place to keep the diff from leaking when you put the cover back on. You'll probably see pieces of the old gasket when you remove the cover (Make sure you scrap it away before you put the new gasket on).
JamesC
Old Feb 17, 2009 | 12:19 PM
GTA BANDIT's Avatar
Engine: 350 Tpi
oh ok i know what you're talking about now lol
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
BlackBoulder
Aug 11, 2015 11:15 PM
