9-Bolt Throwing out fluid; Why??
Old Feb 18, 2009 | 08:35 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I changed out my gears on my 9-bolt posi and went through all the seals/bearings/etc.
Ever since I did that, it pushes out the gear oil out that little breather tube. I'm not running the car hard or doing multiple burn-outs. But the rear of my car gets coated with gear lube within 300 miles. Any ideas??? Nitro-Nicky
Old Feb 18, 2009 | 09:16 AM
big gear head's Avatar
Re: 9-Bolt Throwing out fluid; Why??
How much oil did you put in it? It should only have about 2 quarts.
Old Feb 18, 2009 | 10:55 AM
thomash205's Avatar
My dads ford 9 inch did that for a while, had someone else set the gear up in it and hasnt thrown any fluid out since then.
Old Feb 18, 2009 | 12:09 PM
neagan's Avatar
After the first time, I went and had one of the best shops in my area go through it all. Sure enough; it tossed out the fluid thru that little vent and burned up the posi cones and such. They tried to blame me initially, thinking I had gone to a oil/lube drive-thru that didn't put enough gear lube back in. They ended up having to rebuild it again. Since it's still doing the same thing I thought I'd check here before going back to the shop again.
It's a good question about using the correct amount of gear lube, but I am being really careful since it's an issue that keeps repeating...... Nitro
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
