Tranny will not downshift . Even manually shiftting into 3rd.
Old May 24, 2001 | 11:36 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Tranny doctors I need your help with this one. I installed a kickdown kit on my 700-r4 from Summit. If am at a stop light and I floor it , it goes first, second, third then OD , the problem is once I get to OD it stays there and if I shift into third trying to get my rpms up It won't downshift until like 4-5 seconds later by then If I am at a friendly drag race I am toast. What could be the problem? Could this kit screw up my shifts?Thanks in advance . Note: I tought that even if you've got the kickdown kit(allowing u to stay in OD at wot) you could always downshift to third manually. ANy Help?
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression 186 casting Heads,234dur.488lift exh&int,Edelbrock performer intake, Holley750 vac.sec 400 crank,flat top pistons,edelbrock valve springs and lifters,tranny shift kit,2500 stall converter. Will install 3.73's later on and might go with a more aggresive cam.As of 4/01 added Hooker Headers,2.5inchpipes with 40 s. Flowmasters.Ignition upgrade include: MSD Coil and MSD module.
Old May 25, 2001 | 03:03 PM
poncho9789's Avatar
was the part you are talking about the B&M kickdown valve?
also how easy was the install. I just ordered the gm equivilent for $16 from my local dealership
Old May 25, 2001 | 05:41 PM
Car: 86 z28
I think that's the one. It allows you to go wot in 4th (OD)up to a point.
[This message has been edited by Big454blockchevy (edited May 25, 2001).]
F-body driver
Mar 6, 2023 11:44 AM
RyanJB
May 7, 2016 06:23 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
