t5 speedo gears info needed.... and it's not in the archives
Old May 27, 2001 | 01:09 AM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
i just bought an 84 t5. It has a purple drive gear and a red 18 tooth driven gear. I know the car was a z28 LG4, so i think the rear ratio was, 3.23. What i need to know is are these trans gears consistent with 3.23 rear gears?. Also what will the 3.42 gear equivalent be? Lastly what is the difficulty of the gear change. I looks pretty intense. thnx i hope to get my $325.00 tranny up to speed quickly. THE SHAGGY IROC
'89 SHAGGY IROC
L98 7r4, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc.
so much to do , so little money
Old May 27, 2001 | 02:24 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you search this board you'll find it.
3.42/3.45 gears with a T5 is a purple 7 tooth gear (which you have) and a white 19 tooth driven gear.
For the instructions go to http://www.sethirdgen.org/vss.htm
Its for an automatic but its similar. Since you already have the correct drive gear, just remove the 18 tooth driven gear, and replace it with the 19 tooth gear, and put it back in.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
[This message has been edited by Kevin91Z (edited May 27, 2001).]
junkcltr
Aug 2, 2019 11:12 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
GTAman
Aug 27, 2015 10:29 PM
