junkyard treasure?
Old May 26, 2001 | 11:15 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
junkyard treasure?
I was in the junkyard today and I found what I believe (after studying the car) an 85 IROC. It had a 10-bolt with disc brakes. should I get this rearend? It had TPI and there was no G92 RPO listed. What carrier could it be? What would the stock gear be?
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
Old May 26, 2001 | 11:48 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
It sounds like the rear I bought! I can't remember what year it was now 84 or 85 but, it was a 10 disc and came from a z28. it had the posi 3.23 gears and also had the metric lines. so I lucked out. but, was told the 82-83 have sae lines. hope this helps.
Old May 26, 2001 | 11:53 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Sounds like you've found exactly what I'm looking for!
My local thirdgen salvage yard is telling me that the 10 bolt disc rears aren't all that common compared to the 9-bolt.
I want a 10 bolt disc dammit!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old May 26, 2001 | 11:56 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
if I get it and build it with all the strongest stuff I can find do you think it could take 420+hp?
future mods:
Old May 27, 2001 | 12:00 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
oh yeah and they want $150 for it should I buy it?
future mods:
Old May 27, 2001 | 09:28 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I found an 86 like that. I didn't care what was in it since I was going to change everything anyway. I just wanted the housing with the disk brakes. It replaced the factory 9 bolt with disk brakes that was in my car.
Since then I've built it up with 4.10 gears, 28 spline axles, LPW rear cover, welded tubes etc. Only 6 hard passes on the diff so far and it's still holding up.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old May 27, 2001 | 10:11 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
does it still feel ok? Is it making any sounds? I have only 100 miles on the 9-bolt in my Z(it was installed before I got the car) and it is not taking the power of my engine. I don't know the history of the rear or how it was treated but I haven't done much to beat on it and it isn't liking it.
future mods:
Old May 27, 2001 | 07:45 PM
Engine: ls1, LB9
150 is what I payed they are a bit weaker than the 9 bolt but, the parts are cheeper for them.
they are harder to find but, that doesn't make them worth much.
armybyrd
Sep 28, 2023 12:16 AM
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Damon
Sep 26, 2015 04:29 PM
