TRANNY SWAP: 700R to T-56
Old May 30, 2001 | 07:48 PM
Tom Batts's Avatar
Old May 30, 2001 | 11:29 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
It is easy as pie. Just unbolt one and bolt the other one on. The hardest part is cutting the hole for the clutch master cylinder and that ain't hard either. That's all you need to do is fallow the pattern in the carpet padding and drill 2 holes.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
tonys91rs
Oct 10, 2015 03:31 PM
bjpotter
Oct 4, 2015 07:48 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
