5 speed swap
5 speed swap
I have an 88 Trans AM GTA with a TH-700R4...the steering column has VATS...I blew the trans last week and I have a T-5 to swap in, but I'm not totally sure what all I will need. I know I need to do a pedal, and console change...and I have to install the hydraulic clutch cylinder...but what else will I need? Can I use my current steering column?
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
<font face="Verdana, Arial" size="2">Originally posted by thirdgencompta:
I have an 88 Trans AM GTA with a TH-700R4...the steering column has VATS...I blew the trans last week and I have a T-5 to swap in, but I'm not totally sure what all I will need. I know I need to do a pedal, and console change...and I have to install the hydraulic clutch cylinder...but what else will I need? Can I use my current steering column?</font>
Try this:
http://www.sethirdgen.org/t56.htm
it should help out a bit. if not do a search on this board, you will find most answers.
HTH
1992 Trans Am
Aug 8, 2015 08:16 PM
