Need Help!: Swap '82 4-speed mech to hydralic set up
Old Jun 2, 2001 | 10:33 PM
Hoffboys's Avatar
I'm in the process of trying to convert my mechanical clutch linkage set up to a hydralic set up because I keep snapping of my Z-bar. I picked up the hydralic set up at a junkyard complete with master, slave, bellhousing, brackets, etc. NOW here's the prolem- The car is an early '82 model with a Saginaw 4-speed that was mounted level, as opposed to the 45 degree off-set of the newer models. Thus, the bell housing I picked up is all ****ed wrong for me to use the 4 speed. I need to know if I can use the Saginaw or if I have to find a t-5 or some other set up? I could also use any info on the actual swapping of mechnical linkage to hydralic. Are there any secrets to mounting the set up to the fire wall? do I need to find another clutch pedal?
Any advice or help would be greatly appreciated!
Hoffboy 3
customblackbird
Aug 15, 2021 10:16 PM
colton_carlson
Mar 8, 2019 12:21 PM
nuggie
Aug 25, 2015 01:27 PM
jharrison5
Aug 19, 2015 05:53 PM
