Gears
Old Feb 26, 2009 | 08:04 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Gears
I have a 1987 Iroc-Z with a 305 TPI. I believe my gears are 2.73. If I wish to put 3.23 gears what do I exactly need to get?
I plan to swap a 350 TPI really soon so would those gears run well with a 350?
One last question, will I be able to remove it off any Camaro with those gears?
Old Feb 26, 2009 | 08:31 PM
big gear head's Avatar
Re: Gears
You are going to need a 3 series differential. The 2.73 is on a 2 series and the 3.23 uses a 3 series. You will also need a good installation kit.
Old Feb 26, 2009 | 08:43 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Gears
So I need a whole new differential with the gears in it already?
Old Feb 26, 2009 | 09:22 PM
Re: Gears
You don't need a complete rear end, just the 3 series differential. The differential is the part that the ring gear bolts to and the axles go in it.
This is a 3 series Eaton Posi differential for the Chevy 12 bolt. Just an example.
Old Feb 26, 2009 | 09:25 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Gears
Some questions may be answered from the sticky:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Feb 27, 2009 | 04:59 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Gears
Alright thanks. So would you guys recommend 3.23 or 3.73 gears?
Does this mean I can get the differential off a 4th gen?
Old Feb 27, 2009 | 05:50 PM
JamesC's Avatar
Re: Gears
Yes. You might consider reading the sticky, if you haven't already.
JamesC
Old Feb 27, 2009 | 08:47 PM
Re: Gears
You can get the differential from any 7.5 10 bolt GM rear end, from an S10 truck to a Malibu or Cutlass. You must get one with the correect splines for the axles that you are using. The early ones had 26 splines and the later had 28. I recommend getting a new Eaton Posi. These were never used by GM in the 7.5, but are probably the best street/strip differential for the GM rear ends.
Old Feb 28, 2009 | 02:10 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Gears
Ok thanks. Would you recommend upgrading my gears?
Old Feb 28, 2009 | 02:17 PM
Re: Gears
Many of the 4X4 S10 trucks had 3.42 or 3.73 gears, and some had the 4.10. You can get the gears from one of these and get a differential from a Camaro or Trans Am. Just be sure that you get the 3 series with the correct splines. If you have the money then get new parts. The new Eaton is much better than any of the GM differentials and new gears are much easier to set up. Get a quality installation kit no matter which way you go.
Old Feb 28, 2009 | 03:12 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Gears
Oh alright thanks for the advice.
Old Mar 1, 2009 | 07:58 AM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Re: Gears
The gears depend alot on the tire size and tranny. If you are running stock tire size with the 700r4 automatic I would recommend 3.42 unless you do a lot of highway then I'd go with 3.23. Personally I wouldn't do 3.73 or higher with that 700r4 but I know other would disagree.
Old Mar 1, 2009 | 08:10 AM
JamesC's Avatar
Re: Gears
BTW, the L69 came with a manual and OE 3.73's. In 84 (the only year, IIRC), the L69 was backed with an auto tranny and 3.42's.
JamesC
Old Mar 1, 2009 | 11:55 AM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Gears
Well I have 20 inch Irocs so what would you recommend?
Old Mar 1, 2009 | 01:01 PM
vbMike's Avatar
Re: Gears
It depends. What's the tire size? What transmission do you have?
Old Mar 1, 2009 | 01:05 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Gears
245/35/20 with a 700r4
Old Mar 1, 2009 | 03:02 PM
vbMike's Avatar
Re: Gears
With those taller tires I'd say go with 3.42 for sure or maybe even step up to 3.73 unless your on the interstate a lot.
With 3.42 you'd be at 2000 rpm at 65 mph and 2300 rpm at 75 mph.
With 3.73 you'd be at 2100 rpm at 64 mph and 2500 rpm at 75 mph.
Use the gear calculator below for more help. Select 93-97 f-body A4 for transmission type and enter tire size.
http://www.f-body.org/gears/
Old Mar 1, 2009 | 05:40 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Gears
Oh alright thanks.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
