What shifter to get? Ripper, Megashifter, Hurts?
Old May 31, 2001 | 08:25 AM
Alan84TA's Avatar
I've been looking for a shifter and want to know what you recommend. I've seen people post about the ripper but can't find it anywhere. Did they quit making it? I can't find it on their site. The console megashifter looks good. Does hurts have any good ones?
Old May 31, 2001 | 02:22 PM
mrls199's Avatar
yeah, they still make the Ripper. I have one on my car. You can get them from http://www.summitracing.com for around $165. It really firms up the shifts.
Old May 31, 2001 | 04:05 PM
Like a ROC 89's Avatar
I like this one for all the automatic guys out there!!!!
[This message has been edited by Like a ROC 89 (edited May 31, 2001).]
Old May 31, 2001 | 05:31 PM
TransAm383's Avatar
Just to let you know, the Ripper is a manual transmission shifter. The Maganashifter is for automatics. You'd probably be real dissapointed if you a Ripper for your automatic or vice versa. But whatever kinda trans you have,the shifters listed are great.
Old May 31, 2001 | 10:24 PM
82camaro's Avatar
Car: 82 camaro SC
hurst, not hurts. As in a hurst/olds. I like the megashifter.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Jun 1, 2001 | 12:10 PM
Alan84TA's Avatar
Sorry the hurts was just a type-o... My trans is an Auto. Can you regular shift the Megashifter or is it ratchet all the time? Hey "Like a rock 89" is that the megashifter?
Old Jun 1, 2001 | 12:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I have the Megashifter... it's ratchet all the time. But, it doesn't go into ratchet mode unless you go after 1st, 2nd, or 3rd gear. You can use the trigger to go between drive, neutral, reverse, and park.
On the two times I've had to valet my car since the Megashifter, that's what I told the guy: "To work that shifter, ALWAYS pull up on the center lever." Otherwise, they'll get stuck in ratchet, and I dont' need that.
Don't worry, the shifter's not a pain in the butt for everday driving. I think some guys in the "Appearance" message board posted pictures of their Megashifter...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jun 1, 2001 | 05:53 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
To answer your question to Lik a ROC, that is a Hurst Dual Gate. I had one on a 74 Camaro I had and I loved it. It has a gate on the right side for aggressive use, but the gate on the left is for everyday use. It uses progressive stops on the right side gate to keep you from skipping a gear. Plus you can't go into rev. without pulling the shifter back to the left gate. That could save you a tranny in itself. It's really idiot proof. Good for me.
Old Jun 2, 2001 | 09:43 AM
KED85's Avatar
How much for that Hurst unit?
Can a B & M Mega shifter, work, also?
I have a B & M in storage, I'd love to install it on my 85 Firebird. I do not know if it's for a 3-speed or 4-speed. I'll bet, I could modify it, tho, to work for a 4-speed.
Apperance board has a pic of one?
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Jun 2, 2001 | 11:51 AM
irocbsa's Avatar
I have the megashifter and overall it has been well worth the 100 bucks I paid for it. There have been a few minor problems that I think more than a few people have had problem with. The shift indicator cable on mine broke so it always indicates park. The switches are a pain in the *** to get working properly all the time. I need to go get a new shift **** now too because the clearcoat is rubbing off and it looks like crap. But I love the thing, look awesome and does the job a lot better than that wimpy stock shifter. I am liking the look of that Hurst dual gate, hmmmmmm........
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jun 3, 2001 | 01:14 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The Megashifter isn't always ratchet, with the trigger in the up position it is in straight gate mode, check the instructions again, it clearly explains it.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out
"There is nothing more addicting than speed"
Old Jun 3, 2001 | 02:17 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i saw the hurst shifter in the nextgenparts catelog for $299
yah im thinkin bout gettin for my car too cuz it looks pretty sweet
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
sony xplod cd player,2 12" profile "baja" subs, and a 250 watt MTX amp
$350 for the subs,amp, and box...rattles my car very good!
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
