Leaks in Tranny Cooler Lines
Old Jun 3, 2001 | 09:54 PM
JEFJM's Avatar
I got a new transmission last weekend. I finally got it installed after just about every problem you could think of happened. Anyway, I bought an oil cooler with it and finally managed to get it up into the front ground effect in front of the radiator. I mounted it to the X-shaped crossmembers inside the GFX instead of straight to the radiator, so I have about two inches between the two. My problem is that the lines seem to be leaking at the bottom nipple of the cooler. It takes a second for the lines to pressurize and then I get a pretty good flow from it. Anyone have any ideas?
BTW, If it makes any difference I just ran a short section of line to the stock metal tubing.
Infested
May 22, 2018 11:56 PM
mike_c
Aug 27, 2015 04:32 PM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
