transmission output shaft question
Old Jun 9, 2001 | 04:12 PM
Javi's Avatar
I have an 88 transam GTA and I have a problem. When I put first or reverse on it, I would hear a clunk. Aside from that, everything works fine with the transmission. I thought it was the universal joints, so I decided to replace them. When I took away the drive shaft to replace the U-joints, I noticed that the transmission output shaft was loose. Is it supposed to be that way, or it is supposed to stay put? I would like to know if there is something wrong. If so, is too difficult to fix?
I would appreciate any help. Thanks
Old Jun 9, 2001 | 07:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do you mean loose when the yoke is out? If so, yes.
Do you mean loose when the yoke is installed? If so, it should move in and out, but not (much) up and down or side to side. The yoke tube is a bearing surface to a bushing in the transmission tailshaft housing. They do wear, especially if the ujoints are shot or the shaft is out of balance or not completely straight. The bushing can be replaced, but the tailshaft housing has to be removed to do it.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Reddeath210
Oct 6, 2015 08:20 AM
Dialed_In
Aug 20, 2015 01:45 PM
formula_novice
Aug 18, 2015 08:48 PM
redmaroz
Aug 16, 2015 11:40 PM
