Speedometer Problem
Old Mar 6, 2009 | 05:36 PM
WaltB_FB92's Avatar
Car: Pontiac Firebird
Engine: V-8 305
Transmission: Automatic 4-speed
Axle/Gears: non posi
Speedometer Problem
92 Firebird with a 700-R4 trani speedometer not working
changed speedo sensor and checked 10 amp fuse need
suggestion on other solutions.
Old Mar 8, 2009 | 04:01 PM
LT1-86's Avatar
Car: 86 camaro
Engine: 96 LT1
Transmission: 400
Re: Speedometer Problem
i would do visual on all the wiring make sure you dont have a short or a open somewhere. did you clean up the connection up at all when you changed out the sensor? Did you just check the amp or did you replace it? did you check the connections at your ecu/ecm/pcm? then lastly i would check out the wiring behing the gauges.
Old Mar 9, 2009 | 01:49 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
When you changed the speedo sensor (bolted into the tail shaft, right?) did you check to make sure the gear on the output shaft of the tranny was still there? Sometimes that internal one gets chewed up or comes off its stop and then the two speedo gears are not making contact any more.
Old Mar 22, 2009 | 02:29 PM
WaltB_FB92's Avatar
Engine: V-8 305
I'll check the internal one external looks fine.
Old Mar 22, 2009 | 02:31 PM
WaltB_FB92's Avatar
Engine: V-8 305
Replaced speedo with no results, I'll be looking into ECU next. Excuse late reply
was on vacation.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
