I Need Help: rear end ?s
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Alright i got a 1992 Camaro with a 305 TBI. I found a 1986 rear end from a V6 Camaro. I think this rear-end has 3.42 gears(I will be finding out for sure in a week or so). Alright if I pull this rear-end out and put it in my car will a shop have to install the SLP take off posi?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You'll be taking a step backwards. Your 92 is a better rear end with 28 spline axles and better brakes. Keep your rear end, buy the SLP take-off and instead of buying the 86 rear end for the gears, just buy a new set of gears to install in your 92.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 481.6
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
Transmission: 4L80E/4L80E
If you are getting the SLP takeoff, you need to get 3-series gears.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
