9 Bolt Gears
Old Jun 13, 2001 | 09:49 PM
89Iroc-ZL98's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 5.7L TPI
Transmission: WC T-5
9 Bolt Gears
I currently have a 9 bolt rear with 2.77 ratio gears installed, stock. What is the highest ratio gear that will fit in this rear and where can these be found? Im really looking for something in the 3.40 range (not sure how 9 bolts run). Any help or info is appreciated.
Old Jun 13, 2001 | 10:36 PM
whiterocz's Avatar
unfortunately, your stuck just like i am. 89 model L98 with 2.77 gears in the 9 bolt. there arent any gears avalable for the 2 series carrier for the 9 bolt. there are 3.70's and 3.73's that you can get for the 3 series carrier (3.27's, 3.42's). some guy on here says he will have 3.73s and 4.10s avalable soon as well as 3 series carriers for sale. im sure he will chime in. if you dont wanna wait, get a 10 bolt from any 90-92 camaro or firebird at a junkyard. they are all the same rear no matter if its a z28, rs, trans am, gta, firebird. then you could get it rebuilt tougher with a wider selection of gear ratios.
[This message has been edited by whiterocz (edited June 14, 2001).]
Old Jun 14, 2001 | 08:17 AM
Biochem's Avatar
Car: 2002 SOM z28
Whoa... they only come with like 3.27, 3.42, and 3.70, but I think you also need a 3-series carrier to run them. Good luck finding parts for the 9-bolt too. Cha-Ching!
10-bolts come in many different combos...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jun 14, 2001 | 02:08 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
<font face="Verdana, Arial" size="2">some guy on here says he will have 3.73s and 4.10s avalable soon as well as 3 series carriers for sale. im sure he will chime in</font>
I can not believe it is taking as long as it has to get this to work out (ie having parts available). I know the parts exist, because I personally installed them (3.73 not 3.70) in my car last month.
They still won't be as cheap as the 7.5 ten bolts, but ratios to 4.11 will be available. When everything is finalized, I will post here.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon )
www.koolmeister.com
hectre13
Dec 11, 2023 08:14 AM
junkcltr
Aug 2, 2019 11:12 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
