EXPORT TCC Lockup - Tourqe Converter Lock Up
Old Mar 11, 2009 | 09:18 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I'm looking for info on the Factory ThirdGen Lockup system that was installed on EXPORT F-bodys. This set-up was used on cars with the 700R4 but no ECM to control the lock up feature.
In the past I had acquired an 84 Trans Am that was originally a Canadian car and it had NO ECM from the factory. I used the Engine/Tranny from that car in a 85 Berlinetta that was converted to analog interior and from V6 to V8. At this point in time there is NO TCC lock-up,..... cause' there's no ECM harness or ECM.
I'd like to know if anyone is familiar with the factory GM F-Body system. Here is a pic:
Let me explain; There is a single wire leading into "A" pin on the tranny connector. ( would be the Purple wire on all other 700R4 plugs. ) At the C207 connector there are 3 wires that match the corresponding pins on the ECM harness of all other 700R4 cars for TCC control.
Green: pin "H" (would be Tan/Black ) TCC control convenience center - Or ECM
Lt. Blue: pin "P" ( would be Purple ) Brake Switch
Black: pin "M" Black Ground
On this set-up you can see the vacuum switch. (There are 2 on this bracket because I BELIEVE the car required an additional vacuum solenoid for the hood cowl ) The vacuum switch has 2 pins and 3 wires..... The Blue wire would be to C207 "P" and the 2 green split off the other pin and go to Tranny (pin "A") and C207 (pin "H") The ground wire at C207 leads to a simple "eye" ground connector that gets screwed to the back of the engine head. This ground appears to be separate from the TCC system and would provide ground to whatever is on the other end of the dash harnesses C207 pin "M".
How does this system work ??
The Green wire on this harnesses C207 leads to a switched ground on the ALDL - This is the same switched ground circuit provided to the tranny to activate TCC in the ECM systems. ( the same one that gets switched ground by a custom installed toggle switch for manual TCC control ) How does this set-up know when to apply the switched ground ?? The vacuum solenoid COULD be grounded when screwed to the body - I don't know !
This is a diagram I made showing the system as it is "in my hand";
My concern is this : There is no 4th gear indicator in this system. How does the tranny know that it's in 4th gear in order to apply TCC ? ( maybe it's applied in all gears ?? ) What are the vacuum ratings that will allow the solenoid to provide switched ground and activate the system?? ( I was under the impression that the vacuum solenoid was used as a "Cut-off" during high vacuum - or heavy load - conditions,......... and that's confusing me. The solenoid appears as if it's actually a "cut on" by providing switched power !?!?!
P.S. The tranny and the vacuum Lock Up were taken from the same 1984 EXPORT car. I understand there are differences in the lock-up INSIDE the trannys over the years, but that doesn't matter in this case. The engine tranny have been installed in my 85 Berlinetta for over a year and about 1200 miles without Lock-up installed. ( & no ill effects - yet. )
Anyone have any input ??
Old Mar 12, 2009 | 07:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EXPORT TCC Lockup - Tourqe Converter Lock Up
In the 700R4 there is a location for a 4th gear pressure switch (on the valve body). I know that the ECM'd cars use this to change which set of TCC tables to use. The 4th gear switch status is sent to the ECM.
This pressure switch can also be wired in series with the TCC solenoid to provide lockup only in 4th gear.
The 700R4 can't lockup in 1st for mechanical reasons. So it is also possible that the export setup allows lockup in 2nd, 3rd, and 4th. In this case the 4th gear pressure switch wouldn't be used.
RBob.
Old Mar 12, 2009 | 12:03 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If you'd rather buy the best than figure it out, lemme say that 4 times I've used the PainlessWiring kit. It currently sells for over $120, but I truly love it. It includes everything, and it locks up, in OD only, when there's enough vacuum for the vacuum switch they include. When you give it gas, it unlocks. When you apply the brakes, it unlocks. When you go to any other gear, it unlocks. Truly excellent.
Old Mar 12, 2009 | 10:35 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Thats the same system my 1983 G20 Van had from the factory. The valvebody should have atleast a pressure switch tied to 4th gear. The vacuum switch will lock the converter in 2nd and 3rd gear as long as it is recieving a decent vacuum signal (PORTED, PORTED, must I stress PORTED vacuum and it needs a delay valve in the hose). 4th gear lockup was controlled by the 4th gear switch in the transmission and over-rides the vacuum switch in OD. In OD, unless you are stepping on the brake, your are in lockup. My valve body had a secondary pressure switch that was for the 3-4/4-3 shift and cut power to the TCC during downshift/upshifts. I should also mention that the EGR signal was bled from the EGR valve by a solenoid that vented it to a port on the back of the carb when the transmission was in OD.
Old Mar 13, 2009 | 12:57 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I've tried Painless' kit with both ported vacuum and manifold vacuum, on each car I used it on. Every time, same conclusion. Manifold vacuum. NOT ported.
Old Mar 13, 2009 | 02:32 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Fast, I always wondered what the pulse pressure switches were for. Now I know. The 700R4 has locations on the valve body for various pressure switches, but are not always tapped for them. Such as the '92, only has a 4th pressure switch along with a temperature switch to force lockup in 4th when the tranny temperature goes too high.
For the vacuum TCC lockup on the export system, it could be either ported or manifold vacuum. There will be a difference is how the transmission feels to the driver. This is an area that I played with in the ECM calibration, which is the same difference between ported and non-ported vacuum.
With an ECM setup there is what is known as coast-release. Whenever the throttle is closed the ECM unlocks the TCC (in most/all? calibrations). As the throttle is then opened the TCC locks back up. The driver can usually feel this, and some don't like the way it reacts.
With the 700R4, when the stick is in OD/4th, the overrun clutches are dis-engaged. So on a closed throttle there is no engine braking.
When the stick is in the D/3rd or 2nd position the overrun clutches are engaged.
In this case if the TCC is kept locked when off the throttle it feels like a stick tranny. There is quite a bit of engine braking. With the TCC unlocked there isn't any engine braking.
So the difference between ported and non-ported vacuum to the TCC lockup vacuum switch is along the same lines. Using ported vacuum is similar to how the ECMs are set up. There will be a TCC coast unlock (vacuum ceases).
If using manifold vacuum the TCC will stay locked. Until either the brake pedal is used or the tranny downshifts into 1st. In this case engine braking will occur if the selector is in D/3rd or 2nd.
Can try it both ways and see which works best for your setup.
RBob.
Old Mar 13, 2009 | 07:52 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
RBob.
My Van never handled manifold vacuum lockup at all. It caused the TCC to stay locked and bogged the small 305 on initial tip-in from a roll.
Old Mar 13, 2009 | 08:06 PM
John in RI's Avatar
I haven't connected all the dots - yet; But I'm getting close ! Thanx for the input guys !
I have located a few more tidbits of info that help to complete my riddle. In the 1984 Camaro Shop manual there is a description of the vacuum controlled TCC as well as a block mounted temp switch. Here are those images:
Both switches look similar to the pictures. The Cold Override has 2 pins on it (wire colors are Orange and Black/Red stripe). I found the C/O switch still connected to the 84 Trans Am engine harness. I have not been able to trace the 2 wires yet. I also found this diagram located inside the 1986 Firebird Shop manual:
I knew that not all 700R4's were the same - but I had no idea they were so different !! This "Type 12" version of the tranny was the only version of the various types that shows a single wire input at tranny connector pin "A".
I have yet to see a factory diagram that includes vacuum and I have yet to locate a factory wiring schematics that includes the Vacuum TCC switch or the Cold Override switch. But I'm taking advise and still learning more........ Thanx for the help !
Old Mar 13, 2009 | 08:11 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The cold override switch is new to me, so thank you!
Old Mar 13, 2009 | 08:28 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Gas Engine vehicles had a cold overide as well. It was a TVS, Thermal Vacuum Switch, which blocked vacuum from reaching the vacuum switch until the engine warmed up to around 110-120*F. I live almost right off the service road of a major highway. Jumping on the highway on a cold morning meant I drove around 2-3 miles @ 70 mph, before the converter would lock.
Old Mar 13, 2009 | 08:40 PM
John in RI's Avatar
I could not resist - I traced the wires on the Firebird harness. It appears as if the TCC vacuum harness is complete and should function correctly as pictured above. Since all parts are from the same car they should all interact with each other the way they are supposed to. ( no worries about if the tranny knows it's in 4th or not ! )
The Cold Override switch I found was used to control the hood cowl. I followed the Cold switch Orange wire back to the oil pressure (oil pressure-send signal to cold start.) I followed the Black/Red wire from the Cold switch to the connector for another Vacuum Solenoid. ( high vacuum-send signal ) I then followed that wire from the Vac. Solenoid to the hood cowl connector. ( Open hood flap.)
The harness in my picture above appears to be the only parts of the TCC system for MY application. The Diagram I made also seems to be as accurate as possible for a "Type 12" 700R4 transmission.
Once I manage to get this installed I'll report back to let you guys know if it works or not ! Thanx again for all that detailed info !
Old Mar 15, 2009 | 09:51 PM
John in RI's Avatar
Quick update / Some notes:
I previously described C207 pin 'P' as
( would be the Purple wire on all other 700R4 plugs. ) .........match the corresponding pins on the ECM harness of all other 700R4 cars for TCC control.
87 and earlier cars have the Brake switch to C207 Pin 'P'. 88 and up ( I believe ) the Brake Signal to the TCC ( purple wire ) runs to C100 @'E7'.
The System is installed and I have TCC operation. It was not operational when it was simply "plugged in." TCC system is from an 84 Trans Am with matching 84 TA tranny. The car is 85 Berlinetta, non-ECM 305 with an 85 V6 Engine harness & 88 Coupe interior dash harness. When I first drive the car after installing the TCC I felt nothing. (In my haste to install I didn't notice the difference in C207 'P' ! ) I just re-pinned C207 and spliced into the brake switch ( purple ). I then installed a courtesy light under the dash that was grounded to the body and spliced into the Green tranny wire Leading to "A" on the connector.....
Operation:
* System is hooked to PORTED Vacuum
TCC light gets power in ALL gears. ( regardless of shifter position.) Whenever the Brake pedal gets pressed; power is cut-off. Anytime the gas pedal is pushed to part throttle the Light comes on....... Take your foot off the gas ( at ANY speed in ANY GEAR ) and the light goes out.
From a stop: Press the gas JUST enough to get the car rolling and slowly build momentum,...... (a couple hundred RPM over idle) The TCC light Waits to come ON till second gear at about 1200 RPM
From a stop: Any Gear, Part throttle,...... The TCC light will come ON right away and will stay on until you let of the gas ( "Coast mode" )
While driving: Depends on Manifold vacuum at that time,..... Floor the pedal and the TCC Light goes out. The TCC light WILL come back on while your in WOT ( after vacuum builds up again ?)
When driving at a cruising speed and 'bumping' the brake there is 2-300 RPM bounce in the tachometer and it does have that stick-shift "feel" to it at lower RPMS. I didn't drive a lot so I didn't have a lot of time to test, but that's what I took from my ride !
Old Jan 27, 2010 | 10:07 AM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi , i am presently removing my 700r4 on my camaro 85 350 and installing a T5...i want to remove this tcc lock up ..it has a one wire plug to the 700r4 that goes to the solenoid,,,on the solenoid it has another plug with this white wire..can i cut this?...do i need any of this for a T5 setup?,,thankyou.
Old Jan 27, 2010 | 01:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There is no switched ground in that setup. The lockup of the TCC is mainly controlled by governor pressure on the TCC valve.
Old Jan 27, 2010 | 01:37 PM
mooch1's Avatar
Transmission: T5 WC
so basically i can removed this unit without any issues since i will have T5?..thanks.
Old Jan 27, 2010 | 01:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
After you have the T5 installed, yes.
Old Jan 28, 2010 | 01:40 PM
John in RI's Avatar
Mario - Could you post a picture ????
Ya', When I first looked into the system I didn't know anything about it,... That's when I asked about switched ground. By the time I was done I realized that the system always had power, that the solenoid cut power based on vacuum, and that the brake toggle also used switched power to override the solenoid.
Looking at the tranny diagram, and after testing the system before and after installation of this set-up, I would find it hard to believe that factory non ECM cars used anything other than an electric signal to operate the TCC. It's vacuum operated, but the vacuum is simply used as a switch to turn the electricity on and off. It's power at pin 'A" that locks-up the TCC.... No 12 volts; no TCC lock-up. Sure the tranny internals are probably dependant on each other to operate, but this post is more about the external system and operation rather than the tranny internals.
Old Jan 28, 2010 | 02:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's almost worth thinking of it as the TCC will lock itself up by the hydraulic circuit in the transmission over a certain road speed, and the electrical circuit is there to unlock it during certain conditions.
Old Jun 30, 2012 | 12:22 AM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
I know this is an old thread, but I'm currently running into problems with my Megasquirt TPI setup and TCC operation. I am using a similar vacuum switch from a full size gas truck 700R4 application, with a 1988 IROC-Z 700R4. As I'm controlling the MFI with MS-I, I don't have ECM TCC control, and I know the stock TPI doesn't have a ported vacuum source. As MS-I does not support IAC either, mine has been removed and I have a block off plate with 2 vacuum ports drilled in it (an aborted attempt at a fast idle system, since deleted) mounted in its place underneath the throttle body, with a vacuum port on either side of the throttle plates. Theoretically wouldn't the port ahead of the throttle plates act as a ported vacuum source for the TCC vacuum switch, effectively giving me a ported vacuum source on my TPI?
Old Jun 30, 2012 | 07:25 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Chim, i would think the port ahead of the throttle plates would have no vacuum as this was were the original IAC got the air from.
the other thing i was thinking about with your set-up. if the way Aperion describes the system in his last post for the early system, the '88 700R4 does not have the tcc valving like the earlier ones do. therefore you don't have a hydraulic lock-up circuit. by '88 almost all had went to total ecm control and the valve bore for the tcc hydraulic circuit either had plugs in it or was cast over. if the megasquirt system you have does not support tcc lock-up, you will most likely have to use an aftermarket set-up such as the painless one that Atilla was suggesting to the OP.
Old Jul 1, 2012 | 10:50 PM
If you're referring to the location in the valve body for the TCC solenoid, yes the '88 700R4 still has hydraulic lockup control, as do all 700R4/4L60 transmissions used until 1993. The 4L60E is what you are thinking of, introduced in 1993 in the F Body and features total ECM control. Visual inspection of my transmission confirms the presence of a TCC solenoid, 4th gear switch, and a temperature switch, and is confirmed according to the book "GM Automatic Overdrive Transmission Builder's and Swapper's Guide" by Cliff Ruggles. The only operational difference between my unit and the OP's is the method used to trigger the solenoid, I.E. a vacuum based signal or an ECM referenced one.
If the former IAC vacuum location I have will function as an effective ported vacuum source on my TPI, then I will give it a try.
On an unrelated note, on a junkyard trip yesterday to get a replacement 700R4 electrical plug I came across a freshly placed '86 IROC-Z with a TPI throttle body airfoil and a Z28/IROC-Z hood in excellent shape, both for only $35.
Old Jul 1, 2012 | 10:58 PM
87zjeff's Avatar
the tcc solenoid does not go in the valve body. it goes into the pump. this is not what is meant by hydraulic lock-up control.
the early valve bodies had an actual valve in the valve body for lock-up. the later ones such as the '88 either had aluminum plugs in the bore or no bore at all. i work in transmission hardparts. i know the 700r4 and 4l60e valve bodies. the OP and your origiginal tranny didn't use tjhe ecm to control lock-up. the '88 does. it has to have the electrical signal to apply lock-up.
Old Jul 1, 2012 | 11:11 PM
Yes, but the electrical signal is simply a switched 12V, regardless if it's a ported vacuum switch or a ECM taking a series of various inputs, referencing a table, and providing a path to ground. There is no electronic "brain" in the trans, no solid state circuit.
Old Jul 1, 2012 | 11:26 PM
87zjeff's Avatar
there isn't one in a 4l60e either.
in the later 700r4 the ecm grounded the circuit as you said. all i'm saying is the early wiring will not work as you think it will and will need to use an aftermarket set-up is all.
Old Jul 1, 2012 | 11:52 PM
I have a custom wired application, built off of the later 700R4/4L60 circuit but with a ported vacuum switch instead of the ECM providing the path to ground. My '88 700R4 has a TCC solenoid (brand new in fact), and the wiring has been tested. The only question is whether my vacuum source will function as ported vacuum.
Old Jul 2, 2012 | 11:53 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, unless you drill ports in the appropriate location in the TB.
Easier to use manifold vacuum to a vacuum switch with a throttle-closed microswitch.
Old Jul 5, 2012 | 12:28 AM
Fired up my '88 IROC-Z 700R4 install today with my vacuum controlled TCC circuit, and road tested everything. The vacuum switch works, and my custom circuit properly controls lockup function in both "normal" and "2,3,4" modes without an ECM. I ran the 12V power feed to the TCC to the brake switch (purple wire), then to port "A" on the trans plug. Port "B" (light blue wire) is a ground path thru an On/Off switch in the cabin, with "On" allowing 2,3,4 operation and "Off" 4th gear only lockup by opening the ground circuit path. Port "D" (tan/black wire) is the normal 4th gear only ground path thru a ported vacuum switch, the circuit open when vacuum is present and unlocking the converter. The trans itself features a brand new TCC solenoid, a temperature switch, and a 4th gear pressure switch.
An aftermarket kit isn't needed if you can read a simple wiring diagram.
Old Mar 1, 2018 | 05:01 PM
mjgord51's Avatar
Car: 14 & 96 Camry's, 68 C10,70 Z28
Engine: Depends what vehical I'm driving
Transmission: Also depends which vehical
Axle/Gears: Also depends on vehical
TTT, Interested in this
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
