anyone running a T56 and 400
Car: 90 Camaro RS
Engine: 305 TBI
are u using the stock 400 flywheel? what starter?
thanks
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
thanks
Rick
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
No way could you use the 400 flywheel. Matter of fact, I'm not sure there ever WAS a 400 flywheel, I thought all 400 SBC's came with automatics behind them.
Anyway, even if there was a 400 flywheel, the LT1 push style clutch won't mate to anything except a flywheel for an LT1. And an LT1 flywheel will not bolt up to the 400's 2 piece RMS crank.
All is not lost however, a few companies (including I think, Mcleod and Centerforce) make a T56 flywheel that fits a 2 piece RMS crank. They're pricey, but the only way I know of to make a 400/T56 combo work.
You can still use the stock LT1 pressure plate and clutch disc, or aftermarket.
hey hawk the 400 was not a SBC it was a pontiac motor
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
Dynomax Super turbo Muffler
Custom Air Intake.
"Like a wounded duck i will continue to hobble alone"
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
Custom Air Intake.
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
I have a T-56 bolted to my 400. I changed the clutch set up to a Bob wier hydrolic throw out bearing and bellhousing.that aloud me too use any clutch set up I wanted and get rid of that slopy clutch that came with the t-56.I am pushing 500 HP and no clutch chatter and no slipping. The only problem that I ran into is that if you go with the 153 tooth you would have too drill and tap a hole for the starter.I don't know but I don't think you can put a 168 tooth flywheel with the stock t-56 bellhousing.Check with someone els on that.Check out my web site below.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
406
accel supper ram
afr heads
<font face="Verdana, Arial" size="2">Originally posted by Stormshadow GTA:
hey hawk the 400 was not a SBC it was a pontiac motor</font>
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
<font face="Verdana, Arial" size="2">Originally posted by camaro1j:
</font>
</font>
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
if the 168 tooth flywheel doesn't fit, then what is the biggest clutch that can be run with a t-56?
BlackphantomZ28
Apr 24, 2016 08:14 AM
BlackphantomZ28
Aug 31, 2015 10:29 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
