Need gears for a 9 bolt
Old Jun 14, 2001 | 10:07 PM
Suaveat69's Avatar
Anyone know where u can get 9 bolt gears either new or used in 342 or 373 for a good pirce, under 200 bucks.
Old Jun 15, 2001 | 02:05 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
New, impossible. The only ratio available is 3.70's, and they cost over $400. Used, you'll be lucky to find them, but they're out there. You'll have to search the classifieds and junkyards.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jun 15, 2001 | 09:55 AM
Suaveat69's Avatar
reider racing makes them as well as randy's ring and pinion. Jegs carries torque line gears as well. Strange makes them as well. But they r all 300 to 375 in price. Thanks for the reply.
Old Jun 15, 2001 | 01:35 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
<font face="Verdana, Arial" size="2">New, impossible. The only ratio available is 3.70's</font>
OK, one more time, that is not a correct statement. I have 3.73's (not 3.70) in my car. Ratios to 4.11 will be available (also new series 3 carriers and other 9 bolt goodies) if i can ever get things finalized.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon )
www.koolmeister.com
Old Jun 15, 2001 | 01:50 PM
Kevin91Z's Avatar
Miles, I know. But I meant RIGHT NOW from current aftermarket manufacturers in the United States. They only sell 3.70 ratios.
Old Jun 15, 2001 | 03:54 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
US Gear/Strange 3.70 Ring & Pinion 296.99 @ Jegs.
Precision Gear sells the cheapest and most complete overhaul kit. All Timken Bearings. I paid 99.00 2 years ago. It may have gone up a few bucks since then. New Timken axle bearings cost me about 12 bucks each @ auto zone. If you have a 2.77 carrier you'll need to get one from a G92 car. I bought a bad posi carrier from a 3.27 car for cheap. The guts are identical, so if your posi is good just swap the guts from yours into the bad one. You can even check the tech articles for Karl Hunter's tip on 9 bolt posi's. Good Luck! Hope this helps.
Old Jun 15, 2001 | 04:54 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
<font face="Verdana, Arial" size="2">Miles, I know. But I meant RIGHT NOW from current aftermarket manufacturers in the United States. They only sell 3.70 ratios. </font>
OK, I'll go for that , atleast for now .
Miles
Old Jun 16, 2001 | 06:07 PM
Suaveat69's Avatar
Anyone want to sell any ration of gears?
hectre13
Dec 11, 2023 08:14 AM
junkcltr
Aug 2, 2019 11:12 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
