wheel offset, backspacing and bolt pattern?
Old Mar 13, 2009 | 07:04 PM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
i really like the way aero 59 series wheels look and think they would look amazing on my car. anyone have them? also know what the specs are for the factory rally wheels i have tires on all mine and cant measure. thanks a bunch
Old Mar 13, 2009 | 08:01 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: wheel offset, backspacing and bolt pattern?
First, offset and backspacing are different ways of expressing the same aspect of whether or not the wheel will clear your suspension. If you want Aero brand wheels, you need a 15x8" wheel with a 5 lug on 4.75" bolt circle, and 4.5" of backspacing. I recommend you don't put BFGoodrich Radial T/As on the front of a third gen. You can run a 235/60R15 or 245/60R15 on all 4 corners, and up to a 275/60R15 on the rear.
Old Mar 13, 2009 | 08:03 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Oh, I neglected your other question. nearly all Chevy RWD car 15" wheels are 15x7" with a 4.25" backspacing.
1992 Trans Am
May 10, 2023 07:19 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
SPEEDY Z28
Wheels and Tires
Aug 24, 2015 06:26 PM
kah992
Aug 19, 2015 02:55 PM
