Can a regular clutch fit on the T-56?
Subscribe
Jun 17, 2001 | 08:18 PM
I'm doing a 383 motor in a 91 Z28 with a 305. I'm using a older 350 4 bolt block from a truck. It is a two-piece main seal. The kit I used is a 383 externally balanced. What can I do for a flywheel and clutch. I do not want to use the pull-type clutch and I was wondering if you can use the regular style like the T-5's.
Reply 0
Jun 18, 2001 | 01:41 AM
As far as I know, the only way to use a T5 clutch with a T56 is to get the T56 conversion package from Sallee Chevrolet, which includes the specially prepared T56 trans. The regular T56 from a 93-97 f-body requires its own clutch. For a flywheel, contact McLeod.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Reply 0
Jun 18, 2001 | 01:53 AM
Doesn't the Spohn kit use an adapter plate and require the driveshaft to be shortened 2 inches, but uses the stock T-5 clutch and bellhousing assembly?
Reply 0
Subscribe
