With the Lt blue drive gear for the speedo how do u put it back on?
From: Newark,NJ The state where racing on I 78 rules.
I ve just installed the Gry & Lt blue tooth speedo gears for the 2.77 to 3.73 rear end gear swap. When i put it all together the the speedo was working fine. After about an hour of driving the speedo went dead. I jacked the car up pulled the electronic speed sensor from the side of the trans & found that the gear thats on the output shaft of the trans had moved completely out of position & it took a couple of teeth with it! Im suppose to get my new speedo today & was wondering how can u tell if the little metal locking tab, that the gry gear sits on, is in the right position? It felt right before but i was all wrong! please guys help me out on this one & I'll gladly pay u on tuesday for a hamburger today (wimpy from popeye)!
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
3inch
njdaewoo@excite.com
383sb engine
smog pump by-pass
db057
Aug 11, 2015 10:11 PM
beachrodder
Aug 7, 2015 04:27 PM
