9 bolt rear - questions
Car: 87 Z28
its out of an 89 Iroc, what gears does it have... i think its either 2.77. 3.23. or 3.42 but can someone verify, and is there any way to tell for sure which it has.
look in your center console and look for the RPO G92 on the sticker in the console.
auto w/ G92 = 3.27
auto w/o G92 = 2.77
standard w/ G92 = 3.42
standard w/o G92 = 3.27
[This message has been edited by whiterocz (edited June 14, 2001).]
auto w/ G92 = 3.27
auto w/o G92 = 2.77
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Standard without G92 is a 10-bolt 3.08.
If you have the gears themselves, its written on the gears what ratio it is. If you have the whole rear end, you can turn the wheels once and count the number of times the yoke turns. If its still in the car, you can jack it up, put the trans in neutral, and then count as you turn the wheels.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
There should ba a code on one of the axel tubes. I know that it is on the foward inner section but I am not shure what axel tube. a hayes manual(I think mine is still in N.J.-it could also be the chilton-oh well) has all the codes. By the way, bring a wire brush- there was allot of road grime on mine.
The yoke is where the driveshaft attaches to the rear end. You're counting the number of times that turns as the rear wheels turn. It'll be either 2 3/4 times (2.77), 3 1/4 times (3.27) or 3 1/2 times (3.45).
<font face="Verdana, Arial" size="2">Originally posted by stroked89:
this is a little off topic...but i've got an '89 formula ws6(just a 305) anybody know what rear i have? </font>
<font face="Verdana, Arial" size="2">Originally posted by speeddevil:
I have a 9 bolt rear in my 85 trans am and the only stamp I can find on it is "borg warner". Does anyone know if this was stock or something added later?</font>
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
