9 bolt axles and brakes
Old Jun 19, 2001 | 11:15 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
Hi all,
How do i pull the axles out of a 9-bolt?
I know it's nothing like a 10 bolt pinion bolt c clip thang. It Un bolts from where?
I just got a nine bolt out of the junkyard part # 10054239 w/3:27:1 (1988?) and need to pull out the axles. I'm putting my drum brakes from my ground up 10-bolt on the nine. The calipers and related are junk.From the measurements i've taken so far, this will be a simple swap. The 10 bolt will be junk when i'm done because i have to cut off the ends (ears), modify, and bolt to the nine. I'm doing this because i don't want to spend at least $500 in parts to get a brake system i don't want up to snuff. Calipers, hoses, cables, master, porp valve, etc. I'd rather put the $$$$ toward some Baer claws and and a nine inch i plan on in two years. Right now i just want to be back on the road.
Has anyone put drums on a 9 bolt before or am i a pioneer? If so i'll take pics and e-mail them to anyone who might be collecting data on 9-bolt rears.
How is the nine bolt as a whole? It looks much more HD as far as webbing, tubes, etc. Has anyone scattered a 9 bolt? My 10 bolt lasted through 15 years of me beating it before it scattered. I'm assuming the cone type posi unit will take more abuse....????
Thanks for reading/responding to my ramblings.
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
Painter @ Chevy dealer
GM junkie
[This message has been edited by 82 TRANS AM (edited June 19, 2001).]
Old Jun 19, 2001 | 11:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Edit your message. You started calling the 9 bolt a 9 inch.
9 bolt axles are held in just like a ford 9". They're bolted on from the outside. You'll see the bolts behind the rotors.
The 10 bolt backing plate won't fit on the 9 bolt without some modifications. The bolt holes won't line up.
I ran 11.8's with a 3.27 geared 9 bolt before swapping to a 10 bolt because gearing and aftermarket performance parts were easier to get.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jun 20, 2001 | 10:30 PM
Car: 82 T/A WS7
Engine: Pontiac 400
Put the backing plates (drum) on the 9-bolt and it is a snap. A little trimming here and there (very little) and 4 holes to drill. Piece of cake really. It seams the 9-bolt was designed to make this swap a possibility maybe GM thought it could happen so it was made that way. The only thing that would make it a perfect swap would be a little bit different design of the backing plate.
Old Jun 21, 2001 | 12:03 AM
Fastcamaro87's Avatar
ok now i am doing the exact opposite, i have a disc brake 3.45 9-bolt that spit out a tooth off of the pinion gear, and i also have a spare drum brake 10-bolt with richmond 3.73`s how hard will it be for me to put the 9-bolt disc setup on the 10-bolt??
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box K&N air filters,TB coolant bypass ,polyurethane tranny and torque arm mounts, K&N oil filter,Mobil 1 synthetic oil 10w30, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
