3.73 or 4.10
Old Jun 20, 2001 | 02:19 AM
BryanJ's Avatar
3.73 or 4.10
Which gear should I go with, I have a rebuilt 305 with a cam that pulls good from 3k-6k. is it worth it to go to the 4.10's or would that be too steep, I also will be getting a 2800 stall just not sure which brand. I have 2.73's now.
Thanks,
Bryan
86 Irocz, 305 bored 40 over, 211/221 comp cam,paw rocker arms 1.5,10:1 comp., stock heads, 100 shot of nitrous,
soon to be airflow research 190 cc heads, 373 gears to replace 273, and induction work
Old Jun 20, 2001 | 03:48 AM
ws6formula89's Avatar
You will like more low end torque 4.10s produce. If you have a cam that pulls thru that range, then you definitely want a 3000-above torque converter, and 4.10 gears. The 3.73s IMHO don't run as well with high rpm camshafts as 410s do (they will do great though, this opinion is solely based on a fun factor ). I like the 4.10s with my LT4 cam: sometimes theres too much wheelspin though. It is really fun slammin the throttle to the floor, and powersliding down an empty road. GOTTA LOVE TORQUE! I love 3.55 and 3.73 gears to death, but I think they perform better in turbo and s/c cars. But with cams, get the 4.10, and have fun!
Thanks- It's 4 in the morn, I'm ramblin!
-ws6formula-
1989 Pontiac Formula WS6
69,000 miles.
305 TBI, 4.10 gears, SLP Zexel/Torsen Limited Slip Differential, 700r4 B&M TransPak, LT4 Hot Cam/Valvesprings, GM Aluminum Driveshaft, 2700 RPM Stall, Edelbrock Performer RPM intake manifold, Turbocity TB, Runs 14.9 @ 110 mph. Dyno'd Bone Stock @ 172.6 rwhp, 266 ft-lbs. of rw-torque.
Old Jun 20, 2001 | 07:19 AM
ERIC'86IROC's Avatar
I think with the cam in your sig that 4.10 gears and 2800 stall will be too much for the power band of that cam especially with nitrous. To remove any doubt call Competition cams. They will recommend proper gear ratio and a stall converter.
I would go with 3.73's and 2400-2600 rpm stall converter. With your cam I think you will be faster with this combo. If you just want to spin tires go with the 4.10's and 2800 stall.
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
Old Jun 20, 2001 | 07:30 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Yeah I say go with the 3.73 because u will go through your powerband so fast with the 4.10s. The small cam & heads on your motor wont pull on the top side so your going to slow down!
Remember to much of anything is not good for u.
njdaewoo
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
Old Jun 20, 2001 | 08:11 AM
purpleworm's Avatar
I am going to the 3.73's from 3.42's this weekend and I am a little bit nervous about it. I love the 3.42's. I get good ilage and great power off the line. The 3.42's have bit the dust so I bought an auburn posi rear to put in. I would add a posi if you can afford it.
Old Jun 20, 2001 | 10:13 AM
Didn't you see that my opinion was solely based on a fun factor ? But I agree, get 3.73s if you are more concerned about top end. I've had my Formula past 110 with 4.10 gears. Once again I agree, there is too much wheelspin with my 4.10 gears (read on my post above)! I wish they had a 3.90 gear for our 7.5 rears. I think those would be just right for our cars.
-ws6formula-
69,000 miles.
[This message has been edited by ws6formula89 (edited June 20, 2001).]
Old Jun 20, 2001 | 11:00 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I upgraded to 3.42's from 2.73's and I wouldn't think of going lower than that unless I was building a strictly racing engine. I have dealt with lower gears (3.90's) in another engine with a high lift cam and I did not like how I lost alot of top end.
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc,234dur.488lift exh&int,Victor Jr. intake, 770 Holley Avenger vac.sec 400 crank,flat top pistons,tranny shift kit,2500 stall converter. 3.42 ,Hooker Headers,2.5inchpipes with 40 s. Flowmasters,MSD coil,MSD module.
Old Jun 20, 2001 | 11:29 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
<font face="Verdana, Arial" size="2">Runs 14.9 @ 110 mph</font>
Your kidding, right.
Old Jun 21, 2001 | 12:43 AM
No, I've been explaining how I had too much wheelspin thru 2nd gear, then hooked up and accelerated over 100. I would've been in the mid-hi 13's if I would have hooked up on the line. Why is it so hard to believe? I know of a Mustang with 4.10s that ran a 13.8 over 115 mph. I just couldn't get any traction, no VHT put down. Read the TBI posts people have been giving me s*it about it, and I'm tired of explaining it to every single person. It is physically possible to run that bad of a time with that mph. It's not impossible. I hit the throttle half way, sending me sideways through 2nd, then hooked and threw me back into the seat and I saw the speedo jump to 110. The car accelerates very fast with 4.10s, but it just doesn't like seeing 120 mph. I was almost redlining going 110. I will be taking that bad time down...so no one will bother me anymore.
-ws6formula-
69,000 miles.
6speedIROC
16
Mar 15, 2023 08:33 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
S10K20
Oct 7, 2015 06:45 PM
JSDaddy189
Sep 26, 2015 03:50 PM
whyt86roc
Sep 10, 2015 10:03 PM
